| ripper911 |
Aug 21 2010, 08:38 AM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
So, then. I'll be attempting to change my clutch today, I don't really work on cars very much, so I am going to be asking you people some questions.
First, besides a flywheel lock and the alignment tool, do I need any other special tools? Someone here suggested using four jackstands to only raise the rear end, how does that sound to the others here and where do the stands go for stabilitys sake. would putting the front of the car on ramps and the rear on stands to have the whole thing in the air be a good idea? or the other way around... anything that might be of use is needed from all of you whom are more experienced than myself. I have no clue what I'm doing, but I'll follow the procedures and hope I'm up to it. I'm about to go buy the parts, and go to my dads house to use his garage/tools. I'll be posting pics if there is any trouble. I will have the 914 914/6 handbook, the haynes manual, and the Dr 914 procedure that comes with the kit. Thanks in advance! (IMG:style_emoticons/default/KMA.gif) |
| pcar916 |
Aug 21 2010, 09:02 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
So, then. I'll be attempting to change my clutch today, I don't really work on cars very much, so I am going to be asking you people some questions. First, besides a flywheel lock and the alignment tool, do I need any other special tools? Someone here suggested using four jackstands to only raise the rear end, how does that sound to the others here and where do the stands go for stabilitys sake. would putting the front of the car on ramps and the rear on stands to have the whole thing in the air be a good idea? or the other way around... anything that might be of use is needed from all of you whom are more experienced than myself. I have no clue what I'm doing, but I'll follow the procedures and hope I'm up to it. I'm about to go buy the parts, and go to my dads house to use his garage/tools. I'll be posting pics if there is any trouble. I will have the 914 914/6 handbook, the haynes manual, and the Dr 914 procedure that comes with the kit. Thanks in advance! (IMG:style_emoticons/default/KMA.gif) First of all don't forget to undo the ground strap first, and reconnect it last after burnishing all contact surfaces. Are you leaving the engine in the car? If so then the following applies. Regardless, without a lift it's a two man job to be safe about it. Too many things to watch I put my car up in the front also because I want to inspect the entire thing if it's gonna be up in the air anyway. The butt will go a little higher to give myself room to navigate. But I want it low enough to get a tall jackstand under the motor to hold it up while the transaxle is off. Makes it easier to jack up the unit while putting it back in too. Good luck |
| BarberDave |
Aug 21 2010, 02:06 PM
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
(IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Sorry discription below ! Dave |
| 1970 Neun vierzehn |
Aug 21 2010, 02:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
It's an instrument used to "gauge" interest in pictures that are not included in posts. (IMG:style_emoticons/default/poke.gif)
| ripper911 |
Aug 21 2010, 04:45 PM
Alright, so we've got the clutch presure plate flywheel, etc. out.
The procedure says that we need to set the end play using a dial indicator. is this necesary, please help! I dont have a dial indicator, or any shims! What do I do now (IMG:style_emoticons/default/WTF.gif) |
| SLITS |
Aug 21 2010, 04:48 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Oops, re-read your question.
That dimension is set by measuring the movement fore and aft in the case. The shims are behind the flywheel. Replacing a clutch does not change the end play. If you had installed a reground flywheel, you should check it. As long as it was the same flywheel and you saved the shims, you could get away with reinstallation more than likely and be ok. Oh, there are 3 shims. Now you know ............. You could do it with feeler guages, but you still need a postive place to measure from. Bolt flywheel up with 2 shims. Push crank foreward in case. Rig a stiff wire from a case bolt that just touches the flywheel. Pull the crankshaft aft. Measure the distance from the wire to the flywheel with a feeler gauge. The correct dimension is in the Haynes book. For kicks, let's say it's .004". You take the measurement of the feeler guage you got, subtract .004 and that's the thickness of the 3rd shim that is added to get the correct dimension. Alas, you have to know what thickness your shim is. Harbor Freight ... $20 - $30 bucks for a digital caliper. |
| ripper911 |
Aug 21 2010, 04:54 PM
I haven't removed the flywheel seal, so I'm not to the shims yet.
Can I leave that area alone and just go on with installing everything? I have the 19-piece kit from AA so I am replacing the flywheel, disk, and pressure plate. |
| SLITS |
Aug 21 2010, 04:59 PM
I was typing ... if you don't change the flywheel, you don't need to set endplay.
If your existing flywheel is not scored, blued or cracked, you can just replace the clutch. Scored = deep ridges in the surface Blued = heat spots, blue/black in color on the surface Cracks = cracks If you have a decent camera, post an image of the flywheel surface. |
| SLITS |
Aug 21 2010, 05:09 PM
Or you can just install everything and cross your fingers. You have a bettter than none chance of getting away with it.
| Mark Henry |
Aug 21 2010, 06:47 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
That`s the ultra rare invisible /6 GT myisticalicious gauge.
Nice find! Here's a pic of the back of the gauge: |
| ripper911 |
Aug 21 2010, 06:48 PM
Or you can just install everything and cross your fingers. You have a bettter than none chance of getting away with it. Thats what I'm doing... Now my problem is... I can't get the transmission back all the way on. I have a space of almost an inch and we just can't get it tight. I'm done for today, do more tomorrow. I'll put pics up soon. |
| ripper911 |
Aug 21 2010, 06:50 PM
| jsaum |
Aug 21 2010, 11:29 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
It sounds like the splines aren't lining up with the pressure plate. Did you use an alignment tool when you installed the new clutch and pressure plate? If so and you're sure they're aligned properly try turning the axle with the transmission in gear to turn the input shaft. you should be able to feel the splines line up and be able to push the transmission and engine together. Make sure that you have the transmission and the engine lined up at equal levels. If the transmission isn't level then the input shaft could be hanging up.
Good luck! Jsaum |
| ripper911 |
Aug 22 2010, 08:19 AM
| ripper911 |
Aug 22 2010, 08:23 AM
I ended up using ramps up front and jackstands in the back
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1282486988.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1282486988.2.jpg) Jackstands my grandfather made a long time ago (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/aktion035.gif) |
| GeorgeRud |
Aug 22 2010, 08:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I'd take the transmission back off, loosen the pressure plate bolts and be sure you have the clutch plate properly aligned with the clutch tool inserted all the way. Then retighten the pressure plate bolts, retorque, and the remove the tool. The transmission should line up easily, though you often have to raise the back end up a bit as the natural tendency is to have that end drooping. You can also try twisting the transmission to help align the splines, but it should slide in fairly easily.
Lo-Fi Version | Time is now: 15th March 2026 - 11:45 AM |
