| william1764 |
Aug 23 2010, 08:37 AM
Member ![]() ![]() Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
I'm considering replacing the Triad exhaust system which came with the car. What is considered the best all around system by most? My preference is a single tip product (IMG:style_emoticons/default/confused24.gif)
| TheCabinetmaker |
Aug 23 2010, 08:39 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,365 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Bursch gives good preformance and not near as loud as the triad.
| dr914@autoatlanta.com |
Aug 23 2010, 08:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,231 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| william1764 |
Aug 23 2010, 08:52 AM
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad?
I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? |
| TheCabinetmaker |
Aug 23 2010, 09:31 AM
Hmm, tough Q. maybe a 4 or 5?
| realred914 |
Aug 23 2010, 09:35 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad? I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? if the probelm occured after a gasket replacment and carb rebuiold that is were I'd first look. dont go replacing teh exhaust to fix a probelm that devloped after the carbs and gaskets were worked on. gerneral principle of automobiles is that a probelm that surfaces right after a repair is 99% blilely to be associated to that repair. for quiet sound, the stock muffler is pretty good, the bursh is noiseier my friend has a bursch on his 914, it actually got quieter after he had it ceramic coated. still louder than my stock muffler |
| william1764 |
Aug 23 2010, 10:02 AM
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad? I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? if the probelm occured after a gasket replacment and carb rebuiold that is were I'd first look. dont go replacing teh exhaust to fix a probelm that devloped after the carbs and gaskets were worked on. gerneral principle of automobiles is that a probelm that surfaces right after a repair is 99% blilely to be associated to that repair. for quiet sound, the stock muffler is pretty good, the bursh is noiseier my friend has a bursch on his 914, it actually got quieter after he had it ceramic coated. still louder than my stock muffler The probem was there before the carb work. MUCH less of an issue now but still pops reguarly on decel which drives me nuts. I was told the Triad could be the problem but it was from someone who is not a Triad fan so other opinions would be useful. |
| realred914 |
Aug 23 2010, 10:10 AM
I'm getting a lot of popping on decel even after total carb rebuild, gasket replacements, etc. Could it be the Triad system and if so, is this to be expected with the Triad? I like the simple look of the the Bursch system. On a scale of 1-10 with 1 being the original exhaust and 10 being the Triad where does the Bursch fall in terms of loudness/sound? if the probelm occured after a gasket replacment and carb rebuiold that is were I'd first look. dont go replacing teh exhaust to fix a probelm that devloped after the carbs and gaskets were worked on. gerneral principle of automobiles is that a probelm that surfaces right after a repair is 99% blilely to be associated to that repair. for quiet sound, the stock muffler is pretty good, the bursh is noiseier my friend has a bursch on his 914, it actually got quieter after he had it ceramic coated. still louder than my stock muffler The probem was there before the carb work. MUCH less of an issue now but still pops reguarly on decel which drives me nuts. I was told the Triad could be the problem but it was from someone who is not a Triad fan so other opinions would be useful. exhaust leaks can be a source of decel poping also. make sure that is checked out |
| Bristol |
Aug 23 2010, 10:12 AM
Newbie ![]() Group: Members Posts: 18 Joined: 16-July 09 From: Texarkana, TX Member No.: 10,573 Region Association: None |
Another vote for the Bursch exhaust. I've got one on my 2.0L. I personally think it sounds pretty good, not too loud, in fact a little quiet for my tastes, but I prefer loud exhausts. The "quality" of the sound to me is good with this exhaust. VW owners always crane their heads as they recognize that flat four sound.
Kirk |
| Bleyseng |
Aug 23 2010, 10:28 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I really don't think its the Triad exhaust, but maybe its leaks around the flanges to head. There are copper gaskets that love to leak and cause poping on decel as air gets sucked in and causes the noise.
Check the carb too, sounds like a single carb? I have never been happy with one of those as the long steel runners cause all kinds of running/tuning problems. |
| william1764 |
Aug 23 2010, 10:50 AM
I really don't think its the Triad exhaust, but maybe its leaks around the flanges to head. There are copper gaskets that love to leak and cause poping on decel as air gets sucked in and causes the noise. Check the carb too, sounds like a single carb? I have never been happy with one of those as the long steel runners cause all kinds of running/tuning problems. Dual carbs and the copper gaskets replaced last week as well. The mechanic showed me the gasket under the left carb - it was deformed and streched out...no way it provided a seal. I was hoping that was the "only" problem but evidently not. |
| william1764 |
Aug 23 2010, 10:52 AM
Another vote for the Bursch exhaust. I've got one on my 2.0L. I personally think it sounds pretty good, not too loud, in fact a little quiet for my tastes, but I prefer loud exhausts. The "quality" of the sound to me is good with this exhaust. VW owners always crane their heads as they recognize that flat four sound. Kirk Thanks for the recommendation Kirk |
| Tom |
Aug 23 2010, 12:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I've had a triad on for several years, never had any popping anytime. I really don't think the type of muffler causes this as much as the condition of the muffler/exhaust system.
Tom |
| william1764 |
Aug 23 2010, 12:27 PM
| DRPHIL914 |
Aug 23 2010, 12:34 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,880 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States
I'm considering replacing the Triad exhaust system which came with the car. What is considered the best all around system by most? My preference is a single tip product (IMG:style_emoticons/default/confused24.gif) What year is your car? and how old is the Triad exhaust? let me know if it is for a 2.0, 73 or 74 if you decide to sell, I might be interested. Phil |
| william1764 |
Aug 23 2010, 02:07 PM
I'm considering replacing the Triad exhaust system which came with the car. What is considered the best all around system by most? My preference is a single tip product (IMG:style_emoticons/default/confused24.gif) What year is your car? and how old is the Triad exhaust? let me know if it is for a 2.0, 73 or 74 if you decide to sell, I might be interested. Phil phil - its a 74 2.0...don't know how old exhaust is. i will reach out of i do. tx |
| JmuRiz |
Aug 23 2010, 03:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,616 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
I haven't had issue with my triad...when my car was tuned up and running it.
However, if you want to switch, I still have my old Bursch that I'd sell you, since you're so close. |
| Gint |
Aug 23 2010, 04:47 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
The Triad itself isn't the cause of your popping. And to answer your question, the Triad is the best muffler IMHO for the 2.0/4. The Bursch gets raspy and nasty as it gets older. It's a popular choice because of it's price. But the Triad isn't much more.
| william1764 |
Aug 23 2010, 06:26 PM
Thanks all. I guess I need to further check for exhaust leak. Given I already changed the gaskets is there a way to check without simply replacing again - are there other potential leak sources?
| ripper911 |
Aug 23 2010, 06:37 PM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
What do Y'all think about the tangerine racing 914 evo street headers?
Thats what I'm thinking about doing. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 13th February 2026 - 08:42 PM |
