chrispy |
Newbie ![]() Group: Members Posts: 48 Joined: 5-May 09 From: modesto, ca Member No.: 10,337 Region Association: None ![]() |
i am in the process of reassembling my 1973 914 doors.
the window fuzz is badddd . are there any after market fuzzies out there and how do i attach them....aa price is to high for my budget thanks chrispy |
jeeperjohn56 |
Member ![]() ![]() Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None ![]() |
Hey Chrispy, I got my new fuzzy replacements from AA-(auto atlanta), They were $38.50ea, not cheap but they have them, you trim to size hope that helps. John (IMG:style_emoticons/default/driving.gif)
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Hey Chrispy, I got my new fuzzy replacements from AA-(auto atlanta), They were $38.50ea, not cheap but they have them, you trim to size hope that helps. John (IMG:style_emoticons/default/driving.gif) better than the 57 buck factory ones....AND they are just the same except for the screw holes missing! |
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,269 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
Chrispy,
You'll waste more time (which is money) trying to figure out how to get by on the cheap. Do it half-assed and you'll be doing it again real soon. The AA ones fit perfectly and are worth the money. |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Can you set me straight; there's a window track at the rear of the door, and one at the front. Does this AA fuzz replace both of them?
Thanks, Andy |
jeeperjohn56 |
Andy, The fuzzy strips that are from AA are only the one's for the aluminum strip between door glass and outer edge of door skin. John
chrispy |
all right, all right ! i'ii quit being cheap and order aa fuzzys
thanks for the feed back, chrispy |
tomeric914 |
You'll need to remove the outer aluminum strip from each door to replace the fuzzy strip properly. There are 3 screws typically rusted in place. Get those out and then CAREFULLY push the aluminum strip down to remove it. If you're not careful, you WILL bend the aluminum piece.
After its off, get all of the fuzzy strip out of its track and clean it up real nice. Then look at this thread: http://www.914world.com/bbs2/index.php?showtopic=109244 |
andys |
Lo-Fi Version | Time is now: 30th July 2025 - 09:42 AM |
