| PeeGreen 914 |
Aug 27 2010, 10:45 AM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
Need to get a new battery for a 914 today and recall the 34r works but the 35 is better? Is it just the 35 or is it the 35r?
| mepstein |
Aug 27 2010, 11:00 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,906 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Don't know which is better but there pretty cheap at Costco.
| PeeGreen 914 |
Aug 27 2010, 11:07 AM
Don't know which is better but there pretty cheap at Costco. I get them at cost from the distributor. Thanks though, I'm sure someone needs to know that (IMG:style_emoticons/default/beerchug.gif) |
| RFoulds |
Aug 27 2010, 11:45 AM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 871 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
Come on everyone! I need to know this too! Which Optima Battery is the correct fit for the 914????
I do need to buy one today. and was going to post this as well. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/biggrin.gif) |
| mepstein |
Aug 27 2010, 11:53 AM
I had a thread on this a couple months ago and the consenses was both will probably work. They have almost the same dimentions and as long as your battery cables will reach then you are good. The Costco in my area only carried a 35.
| kkid |
Aug 27 2010, 12:04 PM
Member ![]() ![]() Group: Members Posts: 366 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Check this site and you will get an answer you want.
http://www.1st-optima-batteries.com/index.html I got 35. It's much lighter than 34/34R and negative post is closer to the firewall and can be under the rain tray. |
| kkid |
Aug 27 2010, 12:08 PM
Forgot to mention, you need an adapter to install 35. It comes with a battery for free if you request. Don't know if 34 needs the adapter though.
| RFoulds |
Aug 27 2010, 12:15 PM
thanks. what does the adapter do?
| tod914 |
Aug 27 2010, 12:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
35 is slightly smaller and about 8 pounds lighter if I recall. That's what's in my current car. Prefer it over the 34R. The 35 and 34R have the terminals in the same location.
| Vysoc |
Aug 27 2010, 02:57 PM
Vysoc ![]() ![]() ![]() Group: Members Posts: 589 Joined: 27-August 09 From: NorthWest Arkansas Member No.: 10,737 Region Association: Southwest Region |
I have purchased two Red Top 35's from Costco. First one was for my 911SC, I fabricated a bottom brace from a simple piece of 1" angle to help snug down the battery. The 35 fit fine in the 914, It does not appear to be moving around but I need to make the base fit a little bit more snug. I will mess with some custom pieces to really secure it. Vysoc (IMG:style_emoticons/default/rolleyes.gif) |
| PeeGreen 914 |
Aug 27 2010, 03:43 PM
The 35 just showed up at the shop. I will be picking it up tonight after I get off work. I was just told it came with a few plastic pieces so maybe it now automatically comes with something to make it fit. (IMG:style_emoticons/default/confused24.gif)
I'll let you know. |
Lo-Fi Version | Time is now: 15th September 2026 - 02:22 AM |
