FS: FREE parts (just pay shipping), The space clearing continues... |
hot_shoe914 |
Aug 28 2010, 03:22 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Here are some new free parts and some leftovers from prior posts. IM me for shipping costs (take it all for the best deal). More stuff to come as I continue to go through boxes... Rear shock tower caps, each has a very small tear that is hard to photograph but will not prevent it from looking fine and protecting your Targa top. Fuel pump mount, rubber buffers are good, minimal surface rust. Battery clamp with surface rust. Front deck lid hinges Heater motor housing Fresh air hoses Box O' headlight stuff Will take the fuel pump mount also along with stuff from other post. |
Gint |
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I'll take the shock tower caps, the fuel pump mounts and the battery clamp. I'll PM shipping address. Thanks!
Gint |
Aug 28 2010, 03:24 PM
Disregard my last then. I really need the fuel pump mount. Put me next in kine for that if for some reason it doesn't work out.
pilothyer |
Aug 28 2010, 07:35 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I will Take the Witch's Hats, The Battery Clamp, The Headlight Stuff. Maybe you can combine with the Targa Latch set from other add.
Steve Snyder |
Aug 29 2010, 04:30 AM
Member Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
I will Take the Witch's Hats, The Battery Clamp, The Headlight Stuff. Maybe you can combine with the Targa Latch set from other add. I'm initially going to quote $20 shipping for everything (including the Targa latch set), but that's just a SWAG. If it turns out to be more than a dollar or two less after I get to the UPS store, I'll refund the difference. If it's more, consider yourself lucky. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:09 PM |
