Cooling air control cable, disconected |
Cambo |
Aug 29 2010, 05:47 PM
Member Group: Members Posts: 122 Joined: 21-April 10 From: California Member No.: 11,641 Region Association: Northern California |
I noticed the cooling air control cable is detatched. Don't know how long it's been that way. How is this activated? Do I just reconect it?
VaccaRabite |
Aug 29 2010, 06:29 PM
En Garde! Group: Admin Posts: 13,446 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I noticed the cooling air control cable is detatched. Don't know how long it's been that way. How is this activated? Do I just reconect it? The able that controls the flaps? 1) make sure your bellows is still in tact and working. Otherwise all you will do is roast your motor as the flaps will never open. 2) there should be a wire from the bellows that goes to a pully and up through a small hole in the tin. THis attaches to the control arm via a nut. I am guessing you will find the bellows missing, and the wire was never hooked up with in the first place. Zach |
Cambo |
Aug 29 2010, 06:51 PM
How do you access the bellows? Great, this thing was probably never hooked up. I thought this thing was running hot. Temp gauge doesn't read hot but it's probably not working either...
pilothyer |
Aug 29 2010, 07:22 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
How do you access the bellows? Great, this thing was probably never hooked up. I thought this thing was running hot. Temp gauge doesn't read hot but it's probably not working either... The bellows is attached to a bracket on the drivers side of the engine case above the air guide. The cable is just a cable with a ferrule that passes through a union nut which is screwed onto the bellows. it goes around a pulley and up to the flaps, the flaps default by a spring to the open (warmed up) condition when the cable is disconnected.........Here is a picture of the whole set up: http://www.autoatlanta.com/porsche-parts/p...arts/115-10.php |
Cambo |
Aug 29 2010, 07:28 PM
Thanks, the wire is laying below the arm that opens the flaps. I can just reatatch it, but I'm wondering how to know if the whole system is working once it's reatatched.??
pilothyer |
Aug 29 2010, 07:29 PM
I might add that some say this system is not needed, but indeed it is and is vital to your engine's life. The system is designed to bring the engine temp up to operating temp faster and then direct cooling air to the oil cooler and the cylinders and heads as needed. The system defaults to the warmed up position only if the spring and linkage is properly assembled.
pilothyer |
Aug 29 2010, 07:39 PM
Thanks, the wire is laying below the arm that opens the flaps. I can just reatatch it, but I'm wondering how to know if the whole system is working once it's reatatched.?? Before attaching the cable actuate the arm against the spring tension and listen for the flaps moving and hitting their stops....then look to see that the bellows are retracted to the short position (cold)..... While the engine is cold close the flaps against the spring tension and while holding it there atttach the cable keeping the cable on the tight side......make sure the cable stays put on the pulley (or roller) then run the car to warm it up and look to see that the bellows have expanded out to the long position, thereby allowing the flaps to open. |
Cambo |
Aug 29 2010, 08:05 PM
Thanks, the wire is laying below the arm that opens the flaps. I can just reatatch it, but I'm wondering how to know if the whole system is working once it's reatatched.?? Before attaching the cable actuate the arm against the spring tension and listen for the flaps moving and hitting their stops....then look to see that the bellows are retracted to the short position (cold)..... While the engine is cold close the flaps against the spring tension and while holding it there atttach the cable keeping the cable on the tight side......make sure the cable stays put on the pulley (or roller) then run the car to warm it up and look to see that the bellows have expanded out to the long position, thereby allowing the flaps to open. That's what I needed to know. THANKS!!!!! (IMG:style_emoticons/default/smile.gif) |
VaccaRabite |
Aug 29 2010, 08:14 PM
If the engine is running warm, not having the bellows hooked up is NOT the cause of it.
UNLESS Unless the flaps in the fan housing are also not hooked up. If the bellows is not hooked up, the issue is that your engine will run too cool, not too hot. Zach |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:48 AM |
