What class?, Scca and PCA |
bmtrnavsky |
Aug 29 2010, 09:26 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
Now that my car seems to be running well I'm thinking I may watt to AX it... I have been reading the classes though and I can't figure out what class I want/ need to be in based off mt current set-up.
My car is a 73 2.0 with the following mods: BMW front calipers, 19mm master cylinder, stainless break lines, and cross drilled rotors, stock shocks with 100 lb rear springs, hydraulic lifters, and a petronics in the stock distributer. It is basically set up to be a fun car that gets a bit of spirited street driving and fair weather commuting. There is obviously a lot more I could do, and I'm no pro, I just want to have fun and hopefully be competitive in my class while maintaining good street manners. So what class and what would you do to it next? |
PeeGreen 914 |
Aug 29 2010, 10:07 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Our local PCA would likely allow you in S1 although due to the brake work you would be in P1.
SCCA I would suggest Novice for your first year unless you want to run in a class. Not sure where you'd run but there are many at the AX that would. |
BMXerror |
Aug 29 2010, 10:20 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
I'm not sure on the local classing in Washington, but nationally I'm pretty sure the brakes and ignition work would land you in D Street Prepared. Not a bad place to be at all... Oh yeah, this is for SCCA. PCA gets you more track time for your buck, but in my humble opinion, SCCA makes you a better driver. Either way you'll have a blast. (IMG:style_emoticons/default/aktion035.gif)
Mark D. |
bmtrnavsky |
Aug 29 2010, 10:48 PM
Thanks guys... I'm thinking I really want to do this soon, but I want to make sure future mods don't put me into a class I can't possibly compete in.
PeeGreen 914 |
Aug 29 2010, 11:21 PM
Just take your car as is and get seat time. Then you can decide where you want to go with it (IMG:style_emoticons/default/beerchug.gif)
bmtrnavsky |
Aug 29 2010, 11:49 PM
Just take your car as is and get seat time. Then you can decide where you want to go with it (IMG:style_emoticons/default/beerchug.gif) That's the plan. (IMG:style_emoticons/default/aktion035.gif) Had to get it where I was comfortable driving it more than 30 minutes from home... It's there now! |
Lo-Fi Version | Time is now: 11th May 2024 - 10:02 AM |
