Flywheel specifications, Different 6 vs. 4? |
Bartlett 914 |
Sep 3 2010, 08:31 AM
I am about to do a clutch change on my 2.0 4cyl. Recently on one of Ripper911 threads, Slits posted a link showing the specs for the flywheel. I think that sheet is for the 6. I found the same drawing in the 6 workshop manual. Problem is I have 3 flywheels and according to that sheet, all are worn out. The sheet shows 11mm to be the wear limit on Dimension "C". Mine are all less than 8mm. I have doubts that all have been worked on that many times. Is there a different specifications sheet for a 4 cyl flywheel? Here is a copy of the one I have:
Lo-Fi Version | Time is now: 22nd May 2024 - 01:14 PM |
