I am about to do a clutch change on my 2.0 4cyl. Recently on one of Ripper911 threads, Slits posted a link showing the specs for the flywheel. I think that sheet is for the 6. I found the same drawing in the 6 workshop manual. Problem is I have 3 flywheels and according to that sheet, all are worn out. The sheet shows 11mm to be the wear limit on Dimension "C". Mine are all less than 8mm. I have doubts that all have been worked on that many times. Is there a different specifications sheet for a 4 cyl flywheel? Here is a copy of the one I have:
