> 914World Classifieds Rules
> FS: Lots o parts, Help me clean out the stash
Gigamight
post Sep 3 2010, 11:59 AM
Region Association: Middle East
I have parts from 4 cars I have bought and broken down into parts for my build. I have waaaaay more than I need now, and I need to get rid of a lot to make room and also to help pay to finish my build.
ALL PRICES ARE NEGOTIABLE!!!
Here is a list of some stuff I really want to sell:
6,000 mile 1.8? engine case with fan/surround, oil cooler, P&Cs (need some cleaning on the Cs) still attached. This engine was hardly used! $350
Taco Plate and sensor (in a separate thread) $100 obo
center console with gauges (not tested) $150
Leather wrapped steering wheel $100
Will add more later (hopefully with more pics)
There is engine stuff, sheet metal (some cut, some not) interior stuff and tons of odds n ends. Most I will let go cheap, but some is in great shape and I will ask going prices for.
I am still new(ish) and so I am still learning prices, so I may ask you to make an offer on something I am not sure about. Here are some pics of a small part of the stash:
Replies(1 - 19)
desmo900rider
post Sep 3 2010, 12:00 PM
I'm after front and rear bumper pads, let me know if you have any.
Thanks!
rwilner
post Sep 3 2010, 12:01 PM
No Ghosts in the Machine
I could use a fresh air blower and some 73 2.0L heat plumbing (warm air elbows, heat shields) if you have any.
Gigamight
I'll look at the condition of what I have and let you know.
Gigamight
post Sep 3 2010, 12:03 PM
QUOTE(rwilner @ Sep 3 2010, 02:01 PM) *
I have a lot of fresh air blowers, but they all will need new seals, and I do not have a working vehicle to test them on. PM me if that is acceptable, and we will work out a price.
hcdmueller
post Sep 3 2010, 12:33 PM
Region Association: England
I am looking for L-jet parts. Airbox w/bracket, throttle body to air meter rubber thingy are the two most important. If you have a whole system let me know.
simonr
post Sep 3 2010, 02:10 PM
I need a working AAR for a 2.0
Gigamight
post Sep 3 2010, 02:28 PM
QUOTE(hcdmueller @ Sep 3 2010, 02:33 PM) *
Looking through my 1.8 parts, not sure I have the bracket, but I swear I saw it here at one point. Bear with me...
Gigamight
QUOTE(simonr @ Sep 3 2010, 04:10 PM) *
I'm still new, show me what an AAR looks like, or where it would be mounted
simonr
post Sep 3 2010, 02:36 PM
Its in front of your airbox to the left. If you have a 2.0 litre engine with Fuen injection it will be there . Has two vacuum hoses going into it.
Gigamight
post Sep 3 2010, 02:39 PM
QUOTE(simonr @ Sep 3 2010, 04:36 PM) *
Will take a look on the new parts car. I also have a box of 2.0 parts that until recently were like looking at ancient greek writing, but I am slowly learning, so I will dig in
BRAVE_HELIOS
post Sep 3 2010, 02:57 PM
"Knowledge speaks, wisdom listens"
WOW, lots of stuff!
Would you happen to have the cover that goes on the front end of the center tunnel (just to the right side of the pedal cluster). I am also looking for the "D" shaped washer that helps attach the pedal cluster cover to the body. Thanks! (IMG:style_emoticons/default/biggrin.gif)
pilothyer
post Sep 3 2010, 03:24 PM
I need a pair of the rubber saddles for the fuel tank need a left and a right, they go at each end of the tank also a good condition positive battery cable...
Gigamight
post Sep 3 2010, 03:47 PM
QUOTE(BRAVE_HELIOS @ Sep 3 2010, 04:57 PM) *
WOW, lots of stuff!
Definitely have an extra cover. Not sure about the washer. Typing on my phone right now, ill pm you when I get home.
Gigamight
post Sep 3 2010, 03:50 PM
QUOTE(pilothyer @ Sep 3 2010, 05:24 PM) *
I know I have the saddles, and I have a few harnesses I can look at for the pos cable. Pm you when I get home.
tod914
post Sep 3 2010, 04:50 PM
Hi need an excellent condition passanger side sheet metal for a 2.0. Piece where the spark plugs go in. Factory paint. By chance do you have the round little white rear trunk plugs? I'll take all 3 if have them in decent shape.
Gigamight
post Sep 3 2010, 05:15 PM
QUOTE(desmo900rider @ Sep 3 2010, 02:00 PM) *
Thanks!
I have one bumper pad that was never installed. No idea what side it is for, but the number is 914.5(6-0?)5.085.10 The other ones I have are on the car and I can't guarantee what will happen when I try to remove them, but I can try.
Gigamight
post Sep 3 2010, 05:16 PM
Looks like the only 2.0 heating parts I have are on the car that I am deciding to part or not. I will let you know when that decision is made. As for the blower, let me know (referring to post above).
Gigamight
post Sep 3 2010, 05:32 PM
QUOTE(tod914 @ Sep 3 2010, 06:50 PM) *
Pretty sure I have the plugs you're talking about. Are they the same as the ones that go in the holes under the trunk cross brace? Almost an inch across? Those you can have for just a couple dollars more than the stamp.
2.0 engine sheet metal is still up in the air since the only set I have is on an engine I am not sure if im parting out yet.
tod914
post Sep 3 2010, 05:58 PM
I might be interested in all the sheet metal if you decide not to part it. But would need to see some pictures first. Those little white/clear plugs in the cross member are the ones. I'm missing the tiny one that covers the threads. But, will also take the other 2 larger ones along with it. Thanks Tod
- Lo-Fi Version Time is now: 8th June 2026 - 11:50 PM
