| ChrisFoley |
Sep 8 2010, 03:10 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I was tired of the axle shafts hanging down on a car with the engine removed a long time ago.
I've used bungees, coat hangers, tie downs, etc. to hold them up out of the way while crawling about under the car. Its even worse when you have to move the car and the halfshafts bang around, sometimes jamming a CV joint. Some time ago I came up with the idea of using a 2 ft. piece of cardboard tube over the inner CVs to keep them together but the tube rolls off to one side quickly and one axle falls out. Its only a minor irritation but with the number of cars we have at the shop which are engine-less, often needing to be pushed around from one area to another, I wanted a better solution. So here it is: ![]() The bracket bolts to the rear trans mounts, and the flange/tube assembly acts like an open diff. The flanges will have bolt holes for 3 different CV sizes often used on 914s. ![]() |
| smontanaro |
Sep 8 2010, 03:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Cool... And it's yellow. Will it make engine-less teeners go faster???
S |
| AndyB |
Sep 8 2010, 03:25 PM
The Governor is watching me ![]() ![]() ![]() Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
(IMG:style_emoticons/default/biggrin.gif) Chris I could just leave the drive train in there for you if that would make it easier?
| Bruce Hinds |
Sep 8 2010, 03:30 PM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 763 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
doesn't look like the right side will rotate... how does the car roll? (IMG:style_emoticons/default/idea.gif)
| EdwardBlume |
Sep 8 2010, 03:31 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I don't want to admit that I could have used one of these a couple years ago...
| McMark |
Sep 8 2010, 03:37 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
That's pretty cool! (IMG:style_emoticons/default/first.gif)
Make sure you include a big note in the package "NOT FOR TOWING USE". (IMG:style_emoticons/default/wink.gif) |
| Mark Henry |
Sep 8 2010, 03:41 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
doesn't look like the right side will rotate... how does the car roll? (IMG:style_emoticons/default/idea.gif) Take a better look, the two sides move independent of each other. Chris did that as a low tech diff so you're not fighting a solid shaft when turning corners. Good job! |
| ChrisFoley |
Sep 8 2010, 03:49 PM
That's pretty cool! (IMG:style_emoticons/default/first.gif) Make sure you include a big note in the package "NOT FOR TOWING USE". (IMG:style_emoticons/default/wink.gif) LOL, Ed already brought that up. No need for a teener being towed to end up on WreckedExotics.com QUOTE doesn't look like the right side will rotate... how does the car roll? The assembly comprises three independent sleeves. It works perfectly. I wish I had thought of this a long time ago. We already have 2 prototypes in use and a third nearly ready for service. Now I just have to figure out a way to make them cheap enough that a few of you guys will buy them. (IMG:style_emoticons/default/wink.gif) QUOTE Cool... And it's yellow. Will it make engine-less teeners go faster??? I was planning to go with orange for production but since we are now doing our own powdercoating in-house I have options. (IMG:style_emoticons/default/smile.gif) |
| sixnotfour |
Sep 8 2010, 03:50 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,266 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
I had a car delivered with the axles flopping around on a mega motor swap weekend, so I came up with this, held up for a 40 mile tow,on two different cars.
(notfortowing) but worked fine. http://www.914world.com/bbs2/index.php?s=&...t&p=1362714 |
| hot_shoe914 |
Sep 8 2010, 05:11 PM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
That's pretty cool! (IMG:style_emoticons/default/first.gif) Make sure you include a big note in the package "NOT FOR TOWING USE". (IMG:style_emoticons/default/wink.gif) You just spoiled all of my fun! (IMG:style_emoticons/default/mad.gif) |
| URY914 |
Sep 8 2010, 06:57 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 133,410 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Chris, you've done it again....
| Mr.242 |
Sep 8 2010, 10:10 PM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
I have ONE more idea and you can take it off the price of mine when I order it.
Deal? Well, here it is......................................... Drill two independant holes that accept hitch pins or grade 8 bolts. This will allow for the locking of the unit that doesn't allow it to rotate. Then you can break the castle nuts on the outside AFTER the motor has been removed! (the two bolts also keep it together for storage =bonus!) It can also act as a LOCK to keep the car from rolling.... (IMG:style_emoticons/default/beerchug.gif) I will take a powder coated ORANGE one! (IMG:style_emoticons/default/first.gif) Mark |
| Jeff Hail |
Sep 8 2010, 10:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Chris Thats a great idea. Kremer used a similar device to "transport" engineless 935's. Funny thing though... that tooling yellow looks familiar. Did you pirate those square tubes from a pickup jig? (inside humor only Chris will understand) Jeff |
| ChrisFoley |
Sep 16 2010, 01:41 PM
Chris Thats a great idea. Kremer used a similar device to "transport" engineless 935's. Funny thing though... that tooling yellow looks familiar. Did you pirate those square tubes from a pickup jig? (inside humor only Chris will understand) Jeff I guess great minds think alike, lol. Heheh. Actually Jeff, we repaired that fixture. I think we still have it here. My fabricator had a bottle of yellow powder he was trying to finish off. This may not be a big seller to individuals but it could be a big benefit to shops with long term projects. A friend with an SC thought I should design one for a 911 too. The spool would be the same. ![]() |
| ChrisFoley |
Sep 16 2010, 01:49 PM
I have ONE more idea and you can take it off the price of mine when I order it. Deal? Well, here it is......................................... Drill two independant holes that accept hitch pins or grade 8 bolts. This will allow for the locking of the unit that doesn't allow it to rotate. Then you can break the castle nuts on the outside AFTER the motor has been removed! (the two bolts also keep it together for storage =bonus!) It can also act as a LOCK to keep the car from rolling.... (IMG:style_emoticons/default/beerchug.gif) I will take a powder coated ORANGE one! (IMG:style_emoticons/default/first.gif) Mark Ooh, I don't think I want to try implementing that idea. Those nuts take too much force for the fixture to withstand. But I'll give you the $.02 off anyway. (IMG:style_emoticons/default/laugh.gif) |
| Mr.242 |
Jan 3 2011, 06:33 PM
Wondering if this product ever came into production?
Also, what does it take to remove the shafts from the trailing arms? If the CV joints are removed can the car still be rolled? sorry, such a FNG question. (IMG:style_emoticons/default/dry.gif) |
| ChrisFoley |
Jan 3 2011, 07:38 PM
Wondering if this product ever came into production? Could be any time now. QUOTE Also, what does it take to remove the shafts from the trailing arms? You can unbolt the stub axle using a big ass wrench or reach into the hole in the back side of the trailing arm and remove the four 12 point bolts that hold the CV to the stub axle. QUOTE If the CV joints are removed can the car still be rolled? Its not wise to move the car without stub axles bolted into the hubs. |
Lo-Fi Version | Time is now: 9th June 2026 - 12:07 AM |
