FS: 2056cc, 2.0, 2.0L, D-Tronic Engine, Motor (SOLD!) |
SchantzMD |
Sep 11 2010, 01:44 AM
Newbie Group: Members Posts: 33 Joined: 15-June 06 From: Riverside ca Member No.: 6,233 |
SOLD! Thanks for all the interest.
2056cc EFI Turnkey engine for sale, complete as seen. ~105-110BHp $5500 914World/Club member price outright, no core is required, but one is appreciated. Shipping available Break-in video can be viewed here: http://www.youtube.com/watch?v=Qn2db7y3VBo...player_embedded Build list: Fully bead blasted and repainted sheet metal and intake system Cleaned and inspected Dual Relief case New 96mm AA Big bore Euro style Flat top Hypertuenic Aluminum P/Cs, ~8.2:1 CR 2.0L 71mm stroke Forged Crankshaft turned .025 under Rebuilt and balanced Connecting Rod set Reground and Nitrated Factory Porsche 2.0L EFI profile Cam & solid lifters Fully Rebuilt #039 casting 3 stud Porsche Heads Green top 380cc/min fuel injectors, cleaned Complete 2.0L EFI system including ECU and Relay box All new fuel, vacuum, and intake runner hoses 2.0L Style 10mm rocker arm adjuster screws New Mahle .025 Rod bearings New Mahle .025 Main bearings New Mahle STD Cam bearings Newly turned 215mm Flywheel New 215mm 6 spring Clutch disc Full Victor Reinz Gasket set All New Seals New Contitech Alternator belt New Engine tin sheetmetal screws New Beru spark plug wires New Autolite spark plugs Rebuilt 2.0L 009 Distributor New Cap, Rotor, Condenser, Points Bosch Super Coil New Bosch oil filter My test Clutch is also included. It is a used 215mm Sachs unit complete with New disc and pressure plate. Mike (951)323-9396 Riverside, CA Attached thumbnail(s) Attached image(s) |
914xprs |
Sep 11 2010, 08:43 PM
Porsche 914 parts and cars Group: NoClassifiedAccess Posts: 21 Joined: 14-July 09 From: Riverside,CA United States Member No.: 10,564 Region Association: Southwest Region |
hey mike,
this is for anyone interested in buying a motor from mike...they are beautiful and knowing the amount of time mike spends on these motors, and the way he stands behind his product and seriously cares about your satisfaction.....THESE ARE A STEAL.!!! hAVE NOTHING BUT GOOD THINGS TO SAY ABOUT HIS WORK.. GOOD LUCK MIKE. TERRY |
SchantzMD |
Sep 16 2010, 08:44 PM
SchantzMD |
Sep 29 2010, 01:10 AM
Lots and lots of interest but no takers yet Last big bore EFI engine at this price. After this one the price goes up. Note: I have another turnkey big bore with dual Webers in the works, completion time should be ~Nov-Dec. |
SchantzMD |
Oct 8 2010, 03:17 PM
SOLD! (IMG:style_emoticons/default/biggrin.gif)
914xprs |
Oct 8 2010, 05:44 PM
(IMG:style_emoticons/default/beerchug.gif) right on bro!!!!hes a lucky guy
Lo-Fi Version | Time is now: 10th May 2024 - 03:14 AM |
