SOLD! Thanks for all the interest.
2056cc EFI Turnkey engine for sale, complete as seen.
~105-110BHp
$5500 914World/Club member price outright, no core is required, but one is appreciated.
Shipping available
Break-in video can be viewed here:
http://www.youtube.com/watch?v=Qn2db7y3VBo...player_embedded
Build list:
Fully bead blasted and repainted sheet metal and intake system
Cleaned and inspected Dual Relief case
New 96mm AA Big bore Euro style Flat top Hypertuenic Aluminum P/Cs, ~8.2:1 CR
2.0L 71mm stroke Forged Crankshaft turned .025 under
Rebuilt and balanced Connecting Rod set
Reground and Nitrated Factory Porsche 2.0L EFI profile Cam & solid lifters
Fully Rebuilt #039 casting 3 stud Porsche Heads
Green top 380cc/min fuel injectors, cleaned
Complete 2.0L EFI system including ECU and Relay box
All new fuel, vacuum, and intake runner hoses
2.0L Style 10mm rocker arm adjuster screws
New Mahle .025 Rod bearings
New Mahle .025 Main bearings
New Mahle STD Cam bearings
Newly turned 215mm Flywheel
New 215mm 6 spring Clutch disc
Full Victor Reinz Gasket set
All New Seals
New Contitech Alternator belt
New Engine tin sheetmetal screws
New Beru spark plug wires
New Autolite spark plugs
Rebuilt 2.0L 009 Distributor
New Cap, Rotor, Condenser, Points
Bosch Super Coil
New Bosch oil filter
My test Clutch is also included. It is a used 215mm Sachs unit complete with New disc and pressure plate.
Mike
(951)323-9396
Riverside, CA
