Alright 'six' guys..., need to pick your brains. |
pcar916 |
Sep 15 2010, 08:55 AM
Greg and Leeds got their butts kicked by another 914-6 last week in Lincoln piloted by Jonathan Jackson (third place unofficially). I have no idea who that is or what the car's all about, but maybe we should ask him what he's running. (IMG:style_emoticons/default/biggrin.gif) Jackson (he goes by "J") is a local racer and has been at AX for lots of years. He's competitive on a tricycle. Come on down to Little Rock (War Memorial Stadium) this Sunday and run your car in the Governor's Cup AX. I just got off of the phone with him and he'll be there with the same car. Ask him yourself. |
jim dorociak |
Sep 15 2010, 09:39 AM
Member Group: Members Posts: 95 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California |
Just another thought. There is a weight issue with aluminum cases, but if you weight the lower cost at machine shop to prep a case, (no case certs needed, no oil pump modification needed) use 78/79 SC heads the port sizes are already a good size and should save you money over porting/polishing to get optimum size. It is possible to destroke the 3.0 crankshaft and make a 2.8 using standard 95mm cylinders with custom pistons being made vs the 92mm cylinders for the 2.8 engine. Jim
Britain Smith |
Sep 15 2010, 10:04 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Greg and Leeds got their butts kicked by another 914-6 last week in Lincoln piloted by Jonathan Jackson (third place unofficially). I have no idea who that is or what the car's all about, but maybe we should ask him what he's running. (IMG:style_emoticons/default/biggrin.gif) Jackson (he goes by "J") is a local racer and has been at AX for lots of years. He's competitive on a tricycle. Come on down to Little Rock (War Memorial Stadium) this Sunday and run your car in the Governor's Cup AX. I just got off of the phone with him and he'll be there with the same car. Ask him yourself. Any pictures of this car, he did damn well at Nationals. -Britain |
pcar916 |
Sep 15 2010, 12:22 PM
Any pictures of this car, he did damn well at Nationals. I'm sure there are. . I'm around that car (and it's predecessor) all the time and will ask him if it's ok to take close-ups. http://www.ozarkpca.org/photos/eve/2010/06.../_KS10664sm.htm http://www.ozarkpca.org/photos/eve/2010/06.../_KS10516sm.htm http://www.ozarkpca.org/photos/eve/2010/06.../_KS10517sm.htm http://www.ozarkpca.org/photos/eve/2010/06.../_KS10510sm.htm That's all I could find since the local SCCA site doesn't have a current Gallery. C'ya |
Sep 15 2010, 12:25 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
6 newbie in the planning stages here. (IMG:style_emoticons/default/happy11.gif) Simple, buy the biggest /6 you can afford. (IMG:style_emoticons/default/biggrin.gif) Andy |
JmuRiz |
Sep 15 2010, 02:23 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Now that sounds like solid advice.
carr914 |
Sep 15 2010, 08:20 PM
Racer from Birth Group: Members Posts: 118,932 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
from John Holmes (IMG:style_emoticons/default/av-943.gif)
pete-stevers |
Sep 15 2010, 10:11 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
Just another thought. There is a weight issue with aluminum cases, but if you weight the lower cost at machine shop to prep a case, (no case certs needed, no oil pump modification needed) use 78/79 SC heads the port sizes are already a good size and should save you money over porting/polishing to get optimum size. It is possible to destroke the 3.0 crankshaft and make a 2.8 using standard 95mm cylinders with custom pistons being made vs the 92mm cylinders for the 2.8 engine. Jim Crank available from Henry Schmidt...3500 plus ... me thinks for the crank |
jim dorociak |
Sep 15 2010, 10:16 PM
Armando at CCR in the Bay area will weld and regrind crankshafts, and even has done special nascar racing rods to boot. I personally like Sir Andy's thoughts get the largest motor you can afford to buy. I do not know about you but going from 110 hp on a stock six to 300 hp on a 993 engine with a special chip sounds pretty exciting to me. Jim
jim dorociak |
Sep 15 2010, 10:25 PM
plus everything you touch once you start getting beyond the 2.7 and even the 2.7 you are trying to get the right compression, correct size carbs, right pistons so you can run cam for carbs, and lets not forget the port sizes - then the stock exchangers are too small and you start loosing power that you are happy to get. You get to the next 3.0 or 3.2 level and it starts all over again - custom pistons so you can run the cam, what size carbs, and now different exhaust system large enough to work with all the new parts, and are you happy now - probably not if 3.2 is great why not 3.4 and now you get to 46 or 50 pmo carbs and the 1.75" exhaust, oh twin plug distributor? It never stops ---- what about the transmission??????? at some point 915 transmission either with a Vellios kit, or Wevo shift or replica 916 shift parts and guys I am telling you it is not difficult to see where a drive train (engine and transmission) can be $15,000 up to $20000. Ouch. Do not forget the SS B&B headers with heat wow. Someone please stop me. Jim
Britain Smith |
Sep 16 2010, 12:29 AM
jt914-6 |
Sep 16 2010, 06:41 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
'Nother pic of J's car....
carr914 |
Sep 17 2010, 05:22 PM
Some Teaser Shots of the 2.8 Twin-Plug RSR on early Aluminum Case (IMG:style_emoticons/default/piratenanner.gif)
T.C. |
Steve |
Sep 17 2010, 08:53 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I'm running a stock euro 3.2 with stock motronic FI, factory six heat exchangers and a bursch muffler. Runs great and I did not have to modify head studs for the heat exchangers. All I needed was the Kennedy flywheel adapter.
Lo-Fi Version | Time is now: 3rd June 2024 - 08:24 AM |
