Mirror Installation - Rant, PO put holes in wrong spot |
tracks914 |
Apr 16 2004, 05:45 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I went to try on the original mirrors that I bought over the winter. The drivers mirror looks good. I went to put on the passenger mirror and ....aaack (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/ohmy.gif) the PO had installed Baby Toranados but didn't use both the original holes on the passenger side. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) The body and paint job has been done for almost a year but I never thought to look at the hole spacing when I was doing all the work. Now I will have to drill out a new hole (hopefully into the original spot inside the door) but will be left with a hole about 1 inch in front of the mirror. (IMG:style_emoticons/default/headbang.gif)
I can always put a nice shiney tapered screw in the hole or maybe find a nice looking black rubber plug to put in it, but I'll be damned if I'm going to redo the door. Right now I just want to drive the car. Attached image(s) |
SLITS |
Apr 16 2004, 05:50 PM
Remove door panel - roll window up - you will be able to see the two nuts that are already welded to the frame - center punch from inside the door thru the nut to get the location to drill - and yes, I have a couple of extra holes in mine from "aftermarket" mirrors. (IMG:style_emoticons/default/mad.gif)
tat2dphreak |
Apr 16 2004, 05:57 PM
at least you didn't have the same jackass as me.. put them on the windshield frame! (IMG:style_emoticons/default/headbang.gif)
Dr Evil |
Apr 16 2004, 07:48 PM
Oh man, that sucks. So sad.
GWN7 |
Apr 16 2004, 09:25 PM
Bad week....extra holes front and side.... (IMG:style_emoticons/default/sad.gif)
Did they get all the cars & trucks out of the sink hole? Did you get any pictures of it? |
tod914 |
Apr 16 2004, 09:34 PM
doesnt look too bad. maybe tap it out abit from the inside, alittle filler and some touch up/airbrush and im sure it wont even be noticable.
maf914 |
Apr 17 2004, 06:44 AM
QUOTE(SLITS @ Apr 16 2004, 03:50 PM) Remove door panel - roll window up - you will be able to see the two nuts that are already welded to the frame - center punch from inside the door thru the nut to get the location to drill I did this several years ago to add a passenger side mirror and drilling those holes was a little nerve racking. Drilling holes in straight body panels is just not a normal thing to do! I center punched and drilled an undersize hole first, to avoid messing up the threads of the existing welded-in nuts, then carefully opened them up using a small rotary file. Then I touched up the holes with a few coats of rust preventative primer, let dry, and installed the mirror. Worked fine. Mike |
tracks914 |
Apr 17 2004, 08:44 AM
QUOTE(GWN7 @ Apr 16 2004, 07:25 PM) Bad week....extra holes front and side.... (IMG:style_emoticons/default/sad.gif) Did they get all the cars & trucks out of the sink hole? Did you get any pictures of it? (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) Front (windshield), side ( door) and underneath....(sinkholes) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) At least I didn't loose any cars in the sinkholes. I think they left a few cars in the hole and just back filled on top. It's too dangerous to go in and get them if they don't present an environmental hazard. They pulled most out though, the ones with gasoline in them.Sinkhole Attached image(s) |
Apr 17 2004, 09:05 AM
The PO of my car used plastic drywall anchors... (IMG:style_emoticons/default/mad.gif) So the holes (he didn't bother with using any of the factory holes) are waaaaay oversize and have this damn plastic thing in them. Some people...
--DD |
Lo-Fi Version | Time is now: 19th May 2024 - 12:40 AM |
