WTB 914-6 hard oil line |
bob |
Sep 15 2010, 09:21 AM
Member Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None |
I need the hard oil line that goes from the block to the oil tank.
Sep 15 2010, 11:44 AM
AA has them in stock. There is also a member on the board who makes them but I don't remember who but Eric Shea will know.
IronHillRestorations |
Sep 15 2010, 11:49 AM
Are you using a factory oil tank? What engine mount are you using? Some of the bulkhead mounts interfere with the stock hard oil line (I call it the oil pipe), and you'll also need the short flex line that connects the oil pipe to the tank.
I have used -12 AN hose and routed it backwards first, and then up along the right side valve cover, and then over to the tank. You can get an adapter to put on the tank at that fitting, so you can run only one long flex line, but it does require some mods. |
Van914 |
Sep 15 2010, 04:48 PM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
GPR used to have the lines make in rubber and in stock with the proper fittings for a stock tank. I used them before I added a front cooler.
Worked great and a lot less trouble than the oil pipe. Van |
bob |
Sep 15 2010, 05:18 PM
Stock, factory Oil Tank... I have the flex line, bracket, etc... this is for a 914-6 not a conversion..... -bob |
0396 |
Sep 16 2010, 08:02 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Lo-Fi Version | Time is now: 17th May 2024 - 04:13 PM |
