bob
Sep 15 2010, 09:21 AM
I need the hard oil line that goes from the block to the oil tank.
Sep 15 2010, 11:44 AM
AA has them in stock. There is also a member on the board who makes them but I don't remember who but Eric Shea will know.
IronHillRestorations
Sep 15 2010, 11:49 AM
Are you using a factory oil tank? What engine mount are you using? Some of the bulkhead mounts interfere with the stock hard oil line (I call it the oil pipe), and you'll also need the short flex line that connects the oil pipe to the tank.
I have used -12 AN hose and routed it backwards first, and then up along the right side valve cover, and then over to the tank. You can get an adapter to put on the tank at that fitting, so you can run only one long flex line, but it does require some mods.
Van914
Sep 15 2010, 04:48 PM
GPR used to have the lines make in rubber and in stock with the proper fittings for a stock tank. I used them before I added a front cooler.
Worked great and a lot less trouble than the oil pipe.
Van
bob
Sep 15 2010, 05:18 PM
Stock, factory Oil Tank... I have the flex line, bracket, etc... this is for a 914-6 not a conversion.....
-bob
0396
Sep 16 2010, 08:02 AM
QUOTE(bob @ Sep 15 2010, 08:21 AM)
BOB ,
I have a new one.. but what are these worth?
