Half shaft Questions |
EdwardBlume |
Sep 18 2010, 04:52 PM
Does it matter which way the half shafts are mounted?
Do you use the same gaskets inside the trailing arm as on the transmission? Why do I have a metal gasket like the paper one laying around here somewhere? |
rick 918-S |
Sep 18 2010, 05:44 PM
Hey nice rack! -Celette Group: Members Posts: 20,463 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Does it matter which way the half shafts are mounted? Do you use the same gaskets inside the trailing arm as on the transmission? Why do I have a metal gasket like the paper one laying around here somewhere? 1) No 2) Yes 3) (IMG:style_emoticons/default/confused24.gif) I've never seen one. Maybe one of the guys that works on these for a living has. |
Krieger |
Sep 18 2010, 11:33 PM
Advanced Member Group: Members Posts: 4,714 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
1.) No, but I have turned them around so that the outer end is now at the trans. They will wear in a different area on cv.
2. Yes, same 3. Somebody gave you the wrong part. |
Lo-Fi Version | Time is now: 21st May 2024 - 05:29 AM |
