Cold air intakes, Any one done this ? V8's? |
TC 914-8 |
Sep 18 2010, 11:29 PM
Senior Member Group: Members Posts: 809 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I'm toying around with the idea of bringing in cool air to my carb. Possibly cutting into the side of my car, don't realy want to do this. Although some 996 or Boxter side intakes would be cool (no pun intended). Has anyone done this? Any pictures with or with out penetrating the side of the car showing cool air intakes.
I took my car out to the Longhouse(liquior store) for Whisky and lotto today and noticed when I got home, 7miles, my air filter and assy was as hot as the valve covers. Using 2000 technoligy, I know it's 2010, there's got to be a better way. Here's a pict of what I got, I almost feel this intake is restrictive for my engine. I have a few ideas, like suckung thru the engine lid with air filters to the carb? Let me know what is out there. Who's done it, what results, Thanks, TI |
TC 914-8 |
Sep 18 2010, 11:42 PM
Here' s Idea 1
messix |
Sep 18 2010, 11:49 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
naw... don't cut in to the side of the body.
a sheet metal tray to seal out the engine heat and vent to the opening of the engine lid would be better. i'll find a link to some thing like it. like this http://www.jegs.com/i/Moroso/710/65960/100...roductId=745281 |
NORD |
Sep 18 2010, 11:50 PM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
Toni I think Phil down on Whidbey Island has side inlets on his Blue 914. The car that tows the blue trailer. Phil and his wife were at the B B Q this last summer. (IMG:style_emoticons/default/driving.gif) |
TC 914-8 |
Sep 19 2010, 12:21 AM
Troy,
I'm all over it, No way would I cut into the side just yet. I fount some cast elbows on Jeggs to adapt to my existing air filter, minus the air filters, then a couple of cone filters. Box them in to suck thru my engine lid and I should be all set. Jegs has what I need and I have a couple of Alum. boxes in the garage, that should work. I'll keep you posted!! Nord, that's what startes this whole thing, I saw Phils intake and said Good Idea, he has (is) a well engineered car. |
TC 914-8 |
Sep 19 2010, 12:29 AM
Don't mind the typo's I'm hitting the bottle I bought earlier :}
jmmotorsports |
Sep 19 2010, 07:47 AM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
Tony,
When I drive my car just a short distance I get dust covering my deck lid and engine cover. This is telling me the air is coming up and out the engine cover. I think if you put your intake air box's where you are thinking the air might be pulled away from them rather than being sucked in. Jerry |
TC 914-8 |
Sep 19 2010, 08:39 AM
Yep, I agree Jerry. Behind the rear window is a low pressure area, air definetly flows up and out of the engine lid, and would be less dense than from the sides, front or under the car. I was also thinking of routing the intakes below the engine, or headers, but it would be picking up alot of road dirt and debris.
For function, side scoops would work best. but I can't get past cutting the sides just yet. |
pjhaun |
Sep 19 2010, 10:03 AM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Tony,
I made this web site about 12 years ago. It shows how I did the side scoops. But since than I have made a few small improvements. The side scoops can be removed to clean the air filters and they also can be reversed on rainy days so the air filters don't get wet. http://members.rennlist.com/bluethunder/projpage05.htm Phillip J. Haun Oak Harbor, Wa. |
Bruce Hinds |
Sep 19 2010, 10:06 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
There was a thread on this a while back which confirmed some thoughts I'd had on the subject. I was driving on a lot of dirt roads and got tired of cleaning my K&N filter and just started buying cheapos.
Thinking the dirty air was coming in over the top and down, I taped over the grill only to find a pile of dirt on top of the air cleaner. It's a definate updraft and my airdam on the front doesn't help. At one point I even made some engine tin to seal off around the headers. It cut down on the dirt, but seemed to run warmer. The LE airdam is shorter in the middle to allow airflow under the car. Normal teener cooling had the little airdams on the firewall to put a draw on the bottom of the cylinders to help the air exit. If I ever get my beast back on the road again I've considered putting an airdam across the bottom of the firewall to see if I can create a down draft in that compartment. Has anyone tried that? |
Sleepin |
Sep 19 2010, 10:15 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I've considered putting an airdam across the bottom of the firewall to see if I can create a down draft in that compartment. Has anyone tried that? Porsche tried that...put it in production too. That is what the two plastic low pressure flaps are underneath the car. |
URY914 |
Sep 19 2010, 10:40 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Side scoops seem like a lot of work for very little gain.
jmmotorsports |
Sep 19 2010, 10:44 AM
There was a thread on this a while back which confirmed some thoughts I'd had on the subject. I was driving on a lot of dirt roads and got tired of cleaning my K&N filter and just started buying cheapos. Thinking the dirty air was coming in over the top and down, I taped over the grill only to find a pile of dirt on top of the air cleaner. It's a definate updraft and my airdam on the front doesn't help. At one point I even made some engine tin to seal off around the headers. It cut down on the dirt, but seemed to run warmer. The LE airdam is shorter in the middle to allow airflow under the car. Normal teener cooling had the little airdams on the firewall to put a draw on the bottom of the cylinders to help the air exit. If I ever get my beast back on the road again I've considered putting an airdam across the bottom of the firewall to see if I can create a down draft in that compartment. Has anyone tried that? The small flaps under the firewall did not seem to make any difference on my car. I am going to make a short belly pan that extends from the firewall to a few inches past the engine mount bar. I have no idea if this will effect the cooling or not. Jerry |
Andyrew |
Sep 19 2010, 11:42 AM
Wrap or ceramic coat your headers and be done with it.. Really no point in doing a cold air intake on our cars. Your going to notice, what a 5hp increase at max? Is that really worth cutting into a clean body?
TC 914-8 |
Sep 19 2010, 01:33 PM
Wrap or ceramic coat your headers and be done with it.. Really no point in doing a cold air intake on our cars. Your going to notice, what a 5hp increase at max? Is that really worth cutting into a clean body? That is a good idea, wraping the headers, to keep the heat away from the air filter. I'm not too worried about HP gains just giving the carb some cool air to breathe. Phil, thanks for the link, I'm still not ready to cut the sides. |
Tom |
Sep 19 2010, 03:39 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
TC,
The main reason to wrap the headers and exhaust systems is to keep the hot exhaust gases inside the headers hot, as hot gases move faster in the header pipes. Gases moving in the header pipes fast is the key to the headers working well. A secondary benefit is not heating up the area around the headers and the problems that result from that, Ie, burned wires, vapor lock, etc. If you have the time and inclination, you could try some different ideas and monitor the temp in the engine bay to see which idea works best. I always wondered why V-8 conversions didn't have tins to separate the cold/hot sides of the engine comp. Maybe because of where the headers go. There does seem to be an agreement that tins on Porsche engines are very important to keep the heat from below from getting to the top of the engine bay. Maybe some custom tin work and wrapped headers would combine to make things better for your car. A side benifit would be keeping dirt out also! (IMG:style_emoticons/default/smile.gif) Tom |
Andyrew |
Sep 19 2010, 03:50 PM
Tom,
The only reason that the tins are need on Porsche engines are because they are air cooled. They need to have the heads have the cool air around the fins so they separate the exhaust from the top and shroud the heads to get proper airflow around them. Really no reason to separate the heat on a v8. As long as you have proper clearance on your wires from the headers you are fine and dandy. |
jim_hoyland |
Sep 19 2010, 05:07 PM
Get that VIN ? Group: Members Posts: 9,300 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Tony,
Seen these ? They were made by Wilco. Wilco made convertible tops and they needed to compensate for the tops intrusion into the engine grill area. So, the scoop was installed. Attached image(s) |
messix |
Sep 19 2010, 05:15 PM
that looks pretty good.... and would't be that hard to do.
TC 914-8 |
Sep 19 2010, 07:10 PM
Tony, Seen these ? They were made by Wilco. Wilco made convertible tops and they needed to compensate for the tops intrusion into the engine grill area. So, the scoop was installed. Not bad It has the 308 look to it. is Wilco still around? I'll do some searching |
Lo-Fi Version | Time is now: 17th May 2024 - 03:13 PM |
