suby conversion ? |
suby conversion ? |
bigvag |
Sep 19 2010, 03:51 PM
Member Group: Members Posts: 50 Joined: 24-August 09 From: Ohio Member No.: 10,719 Region Association: None |
Ok this is for the guys/gals who have a running suby conversion. I'm looking to put a turbo wrx or if price is right sti engine. My ? is what do you have to do to the ecu to make it work in the 914. What can your delete from the wiring harness and have the ecu still work properly.
pktzygt |
Sep 19 2010, 07:05 PM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
Ok this is for the guys/gals who have a running suby conversion. I'm looking to put a turbo wrx or if price is right sti engine. My ? is what do you have to do to the ecu to make it work in the 914. What can your delete from the wiring harness and have the ecu still work properly. That is the question isn't it. If you do a US motor, the ecu should work if you can sort through the wiring. If you do a JDM motor which was designed for different gas, you'll proably end up with a standalone. I'm going with a EMS Stinger and wiring harness from www.outfrontmotorsports.com. These guys are familiar with the swap and can provide a bit of help. I'm sure others will reply here and renegadehybrids is an excellent source of info since they make a business out of it. Good luck. I hope I helped a little. |
bigvag |
Sep 20 2010, 11:38 AM
I contacted renegade they said the ecu need flashed for it to work,which they told me itsaround $1000 to do that. For that price I would go for a used stand alone.
d914 |
Sep 20 2010, 11:42 AM
Bigkat just did a Megasquirt
I have a Stinger there is a link out there There are guys who modified their wire harness and out think the ecu.. That is the overview of the options, depending upon your skills.. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:10 PM |
