QUOTE(bigvag @ Sep 19 2010, 05:51 PM)
Ok this is for the guys/gals who have a running suby conversion. I'm looking to put a turbo wrx or if price is right sti engine. My ? is what do you have to do to the ecu to make it work in the 914. What can your delete from the wiring harness and have the ecu still work properly.
That is the question isn't it. If you do a US motor, the ecu should work if you can sort through the wiring. If you do a JDM motor which was designed for different gas, you'll proably end up with a standalone. I'm going with a EMS Stinger and wiring harness from www.outfrontmotorsports.com. These guys are familiar with the swap and can provide a bit of help. I'm sure others will reply here and renegadehybrids is an excellent source of info since they make a business out of it.
Good luck. I hope I helped a little.
