temp gauge |
temp gauge |
mipstien |
Sep 20 2010, 09:39 AM
Member Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States |
So went to start her up and after starting the gauge for temp is bouncing all over the place when I rev it. Was fine at idle. The gauge worked when I last parked it 3 days ago. It was also about 65 degrees outside coolest its been when I tried to start it.
I did search didn't see anything. Also on a phone so searching wasn't easy. |
Cupomeat |
Sep 20 2010, 09:44 AM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Look for loose wires. As you say it is bouncing when revving the engine (likely making it move in the engine compartment) I'd start with that.
Ground at the gauge is a good one as well. I hope that helps. |
mipstien |
Sep 20 2010, 11:21 AM
Well bouncing isn't quite exact. Its more like going crazy. Mostly stayin hot area but just going ballistic not steady bouncing at all.
simonr |
Sep 20 2010, 11:26 AM
Member Group: Members Posts: 65 Joined: 11-July 10 From: Indianapolis Indiana Member No.: 11,925 Region Association: None |
Mine did that !!! The metal bracket that holds the temp wire into the taco plate was grounding . I bent it away from the place it was grounding to and it is fine now. it is most definatly a grounding loose wire issue . Good luck in your search . I would start with the sending unit
mipstien |
Sep 20 2010, 02:29 PM
taco? lost me at taco
type47 |
Sep 20 2010, 02:40 PM
remote temp sensor sometimes called a "taco plate" or taco sender" or just plain "taco"!
Bartlett 914 |
Sep 20 2010, 03:43 PM
914Sixer |
Sep 20 2010, 06:58 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Most of the wires that run from the sender to the plug under the battery tray are BRITTLE, GOING OPEN OR GROUNDING OUT. Replace the whole wire from end to end. Use heavier gauge wire and make sure it has some sort of extra shield(ie heat shrink, heat resistant tubing) over the wire itself.
Mark Henry |
Sep 20 2010, 07:07 PM
mipstien |
Sep 21 2010, 07:25 AM
if i had to drive my car to get to a lift would that be any issue? its never over heated before.
realred914 |
Sep 21 2010, 11:16 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
if i had to drive my car to get to a lift would that be any issue? its never over heated before. the gauge go crazy as soon as you start it cold? if so then you know the car cant be warm, much less over heating. so you should bne ok, not a real reading. yes the gauge can peg out when shorted. maybe a intermittant short in the wire. if you can comfortably hold the dip stick in your hand with out getting burned, then you can assum e the oil temp is not way too hot. if the dip stick gets so hot as you can not hold it for but a brief seconds then you may really be over heating. |
mipstien |
Sep 21 2010, 11:22 AM
O no its not ever gotten that hot even when 100+ outside and on a long drive.
Lo-Fi Version | Time is now: 21st May 2024 - 03:53 AM |
