914 wont start, help please :! |
dvtorr |
Sep 20 2010, 10:51 PM
Newbie Group: Members Posts: 16 Joined: 5-September 10 From: Colorado Member No.: 12,138 Region Association: None |
So the other day I was driving my wonderfull 914 and the motor shuts of. I pull over and try to start the car and it gives me a clunk noise. Not sure if its the starter or something else. When we try to push start it we go through the process of pushing it and droping the clutch and the back wheels freeze up and the car doesn't start. Any ideass? Pleaswe help!!!
Thanks, diego. |
trent1542 |
Sep 20 2010, 11:21 PM
Member Group: Members Posts: 98 Joined: 19-August 10 Member No.: 12,074 Region Association: Pacific Northwest |
So the other day I was driving my wonderfull 914 and the motor shuts of. I pull over and try to start the car and it gives me a clunk noise. Not sure if its the starter or something else. When we try to push start it we go through the process of pushing it and droping the clutch and the back wheels freeze up and the car doesn't start. Any ideass? Pleaswe help!!! Thanks, diego. year? 1.7, 1.8, 2.0? /6? carbs or FI? rebuilt engine/trans?, when? are you out of gas? lol although odds are, I will most likely not know the problem with your 914, but answering these questions will get your car running sooner and better with the help of the people on this wonderful website and it's forums (IMG:style_emoticons/default/biggrin.gif) |
Jeffs9146 |
Sep 20 2010, 11:28 PM
If it wont roll/start in gear or turn over when hitting the starter in neutral it sounds like it is not good! My guess is it ran low on oil or something like that!
dvtorr |
Sep 20 2010, 11:29 PM
Its a 73, 1.7, carbs
trent1542 |
Sep 20 2010, 11:46 PM
how long since last oil change/fill? does the fuel pump work? make sure your carbs are still tuned right too!
dvtorr |
Sep 20 2010, 11:56 PM
how long since last oil change/fill? does the fuel pump work? make sure your carbs are still tuned right too! No idea when the last change fill. Oil looked dirty and on low. I'm guessing something seized up (IMG:style_emoticons/default/sad.gif). Keep post coming guys. And how much of a project am I gettig into by rebuilding the motor and so on. Thanks! Diego |
trent1542 |
Sep 21 2010, 12:01 AM
how long since last oil change/fill? does the fuel pump work? make sure your carbs are still tuned right too! No idea when the last change fill. Oil looked dirty and on low. I'm guessing something seized up (IMG:style_emoticons/default/sad.gif). Keep post coming guys. And how much of a project am I gettig into by rebuilding the motor and so on. Thanks! Diego You should be fine if your engine was rebuilt within the last 10 years or so. Change the oil and try to start her up! If that doesn't work, it is probably something internally, but I really wouldn't have a clue. If its the fuel pump (I doubt it) then you can post a thread in the classifieds for a WTB 1973 1.7L fuel pump. Somebody here ought to have one working (IMG:style_emoticons/default/wink.gif) |
dvtorr |
Sep 21 2010, 12:07 AM
how long since last oil change/fill? does the fuel pump work? make sure your carbs are still tuned right too! No idea when the last change fill. Oil looked dirty and on low. I'm guessing something seized up (IMG:style_emoticons/default/sad.gif). Keep post coming guys. And how much of a project am I gettig into by rebuilding the motor and so on. Thanks! Diego You should be fine if your engine was rebuilt within the last 10 years or so. Change the oil and try to start her up! If that doesn't work, it is probably something internally, but I really wouldn't have a clue. If its the fuel pump (I doubt it) then you can post a thread in the classifieds for a WTB 1973 1.7L fuel pump. Somebody here ought to have one working (IMG:style_emoticons/default/wink.gif) So if the motor is already seized what would changing the oil do? I ask cause I'm a noob (IMG:style_emoticons/default/tongue.gif). Now I don't think its the fuel pump cause I hear that bad boy run when I turn the ignition. Thanks man! Expecting a reply! Diego. |
benalishhero |
Sep 21 2010, 05:27 AM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Fuel leaking down the carb hydro-locking a cylinder? Did you have a bad raw gas smell when it happened?
dvtorr |
Sep 21 2010, 06:37 AM
Jeffs9146 |
Sep 21 2010, 08:20 AM
QUOTE Fuel leaking down the carb hydro-locking a cylinder? Did you have a bad raw gas smell when it happened? Kind of but there was a semi strong gas smell and super strong. If that is it you can check it very easy by taking the plugs out, put the car in gear and try to roll it! If the motor turns then it could have Hydro-locked but it sounds like a bigger problem because of your first statement: QUOTE When we try to push start it we go through the process of pushing it and droping the clutch and the back wheels freeze up and the car doesn't start. |
VaccaRabite |
Sep 21 2010, 08:52 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Pull the spark plugs.
Put the car in 5th gear. Lift 1 rear wheel in the air, while the other is still on the ground. Make sure the parking brakes are OFF and the front wheels are chalked so the car won't start rolling. Turn the wheel that is in the air. it will be kinda hard to turn, but not overly hard to turn. If you can't turn it, the engine has seized. Time to pull it and see what happened. Zach |
dvtorr |
Sep 21 2010, 11:11 AM
Pull the spark plugs. Put the car in 5th gear. Lift 1 rear wheel in the air, while the other is still on the ground. Make sure the parking brakes are OFF and the front wheels are chalked so the car won't start rolling. Turn the wheel that is in the air. it will be kinda hard to turn, but not overly hard to turn. If you can't turn it, the engine has seized. Time to pull it and see what happened. Zach What's the worst case scenario with a seized engine? Hopefully fixable? Will try that man. Thanks, Diego. |
VaccaRabite |
Sep 21 2010, 12:00 PM
Everything is fixable. If the engine is seized, its going to mean a rebuild, probably including the bottom end which will require splitting the case. If the seize was oil related you are going to want to rebuild the bottom end. if the seize is something in the top end breaking you should also rebuild the bottom end, but that will be your roll of the dice to call.
No one will know what is going to be needed until the engine is down, out, and taken down to a short block (heads and cylinders removed). Zach |
dvtorr |
Sep 21 2010, 04:05 PM
Everything is fixable. If the engine is seized, its going to mean a rebuild, probably including the bottom end which will require splitting the case. If the seize was oil related you are going to want to rebuild the bottom end. if the seize is something in the top end breaking you should also rebuild the bottom end, but that will be your roll of the dice to call. No one will know what is going to be needed until the engine is down, out, and taken down to a short block (heads and cylinders removed). Zach Is it possible to give me an $$ estimate on the rebuild? Like any parts and stuff? Have the tools in hand and have 2 people ready to help me. |
Jeffs9146 |
Sep 21 2010, 05:01 PM
QUOTE Is it possible to give me an $$ estimate on the rebuild? Like any parts and stuff? Have the tools in hand and have 2 people ready to help me. You wont have a clue until you open it up and see whats wrong! It could need a crank or a block, new bearings, pistons even a complete valve job and/or heads! Open it up and take a look! |
steveherman |
Sep 21 2010, 05:09 PM
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
this is not my motor
http://www.914world.com/bbs2/index.php?showtopic=111099 but if you have any internal engine probs you will likely be miles ahead to buy this motor or there is another motor in the classified for much more but it is a dang nice motor. |
underthetire |
Sep 21 2010, 05:24 PM
QUOTE Is it possible to give me an $$ estimate on the rebuild? Like any parts and stuff? Have the tools in hand and have 2 people ready to help me. You wont have a clue until you open it up and see whats wrong! It could need a crank or a block, new bearings, pistons even a complete valve job and/or heads! Open it up and take a look! (IMG:style_emoticons/default/agree.gif) could be 2K, could be 15K. Figure out what happened first. Usually something simple, hope for the best and deal with the worst if it comes to it. |
dvtorr |
Sep 28 2010, 11:31 AM
QUOTE Is it possible to give me an $$ estimate on the rebuild? Like any parts and stuff? Have the tools in hand and have 2 people ready to help me. You wont have a clue until you open it up and see whats wrong! It could need a crank or a block, new bearings, pistons even a complete valve job and/or heads! Open it up and take a look! (IMG:style_emoticons/default/agree.gif) could be 2K, could be 15K. Figure out what happened first. Usually something simple, hope for the best and deal with the worst if it comes to it. Pooop. Well a push rod went thru we think... Whattt to do? Should I just get another motor? I kinda wanna keep the same one. Let me know guys! Thanks, Diego |
Lo-Fi Version | Time is now: 21st May 2024 - 01:06 AM |
