Electrical question 73/74 brake warning lite circuit |
type47 |
Sep 21 2010, 10:51 AM
I'm tracing continuity of all (!) the wires of a project car I have. I think the problem is my car is a 73 (4732914317) and I'm using is the pelican 74 color electrical diagrams; I copied one with the components labeled and say thanks... On the gauge, the brake warning lite is an instrument light powered by a blk/grn/wht wire and a brn/yel wire according to the 74 diagram. I have the blk/gen/white track 44. I don't find brn/yel but I do have brn/wht. While I'm there, there is a large diode brn/wht that I can't find the track of in the schematic.
So 1) What's the diode? Where is it connected? 2) What is the circuit from the other side of the lite? One terminal will be blk/grn/wht so what color wire should I look for, for the other terminal of the lite? |
realred914 |
Sep 21 2010, 11:09 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
the 73 diagram is different than the 74 diagram, they are displayed as sperate ones in the haynes book. that maybe part of the problem in tracing it.
the 73 diagram shows a brn/wht wire from both teh parking brake switch and the hydrolic brake warning switch going to the light. the one coming from teh parking light has the diode inline. Remeber the brake lamp blinks so it power comes from teh flasher relay which goes to the other side of the light that supplies the +12 volt. the switchs (brake failure and parking brake on) simply ground the light The wire from the flasher to the light bulb should be blk/wht color. per the 1973 diagram in haynes. hope this helps. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/chowtime.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/aktion035.gif) |
type47 |
Sep 21 2010, 11:51 AM
Thanks! So the branch with the diode inline goes to the brake warning lite on a 73; the other terminal is the blk/grn/wht.
Lo-Fi Version | Time is now: 21st May 2024 - 11:07 AM |
