Pedal area, Rusted out! |
clow |
Sep 21 2010, 02:40 PM
The Kid Group: Members Posts: 164 Joined: 7-September 10 From: Ontario, Canada Member No.: 12,151 Region Association: Canada |
Hello, I was just wondering if people had any pictures, thoughts and/or opinions on fixing up the pedal area. Is there someone who has dimension of the piece thats bolts (?) on to the bottom side of the floor pans? Any input would be great and pictures of the finished area would be even better!
Thanks, Clow |
EdwardBlume |
Sep 21 2010, 03:48 PM
The pedal area is notorious for sitting water. You can take the entire cluster out fairly easily and pay to have someone here on the site rebuild it.... the person who did mine (I forgot) did an awesome job...
EdwardBlume |
Sep 21 2010, 03:49 PM
Drums66 |
Sep 21 2010, 04:08 PM
...For pic's, do some search's (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) |
clow |
Sep 21 2010, 04:27 PM
Alright, I have done some searches but am not having much luck. Is there a certain phrase I should search? I was going off of "pedal area" and such. Does it have any other name or something that might be more successful?
Thanks, Clow |
realred914 |
Sep 21 2010, 04:28 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Hello, I was just wondering if people had any pictures, thoughts and/or opinions on fixing up the pedal area. Is there someone who has dimension of the piece thats bolts (?) on to the bottom side of the floor pans? Any input would be great and pictures of the finished area would be even better! Thanks, Clow opinion here: before you repair, check the entire rest of floor inside and out for more rust include the rocker areas and the fire wall behind the seats. looks at all low spots adnd all seams. nohting worse than fixing that one rusty spot then a month latter you find more rust and relize it all should have been replaceded together or scrapped (in extrme cases) research for folks selling a pareted out car or check with suplier like High perfromance house for good used rust free part you can buy hwole floor pan if you see the gruond. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) |
nathansnathan |
Sep 21 2010, 05:05 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I think the word you need is 'cluster' as in pedal cluster?
I met Bruce stone, he sold me a pristine ss heat exchanger for a very reasonable price. :-) His specialty is pedal cluster restoration, though, he was saying. I've read that it's a leaking master cylinder that does the pedal cluster in, brake fluid being no good for paint. |
clow |
Sep 21 2010, 08:45 PM
Hello, I was just wondering if people had any pictures, thoughts and/or opinions on fixing up the pedal area. Is there someone who has dimension of the piece thats bolts (?) on to the bottom side of the floor pans? Any input would be great and pictures of the finished area would be even better! Thanks, Clow opinion here: before you repair, check the entire rest of floor inside and out for more rust include the rocker areas and the fire wall behind the seats. looks at all low spots adnd all seams. nohting worse than fixing that one rusty spot then a month latter you find more rust and relize it all should have been replaceded together or scrapped (in extrme cases) Thanks for your replys. This is a full restoration. The car is completely stripped and on a rotisserie. This is the last area to fix up. I will post pictures tomorrow of whats going on with it research for folks selling a pareted out car or check with suplier like High perfromance house for good used rust free part you can buy hwole floor pan if you see the gruond. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) |
clow |
Sep 22 2010, 02:38 PM
Not too sure what happen to my last reply (IMG:style_emoticons/default/idea.gif)
But this is what I have to work with: Interior Bottom side |
FourBlades |
Sep 22 2010, 02:58 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I had the same issues as you. If you look at my 1973 restoration thread somewhere around page 3 or 4 I show what I did. Not a lot of pictures but
some. I got a piece cut from a parted out car and patched it into mine. Then I made little patches to fill in the bottom of the footwell and the tunnel. It took some time but worked like a champ. When I welded in a new floor pan it all fit just right, which was pretty lucky. In post #109 on page 6 I show how I fixed the boxed reinforcement under the pedal area. John |
NC_Colfax |
Sep 22 2010, 03:20 PM
Member Group: Members Posts: 130 Joined: 26-July 10 From: North Carolina Member No.: 11,982 Region Association: South East States |
I have the same problem ....I have sheet metal. It is one of the first things on my list. I have a rock hard gas pedal and I think water/dirt got into my pedal cluster.
Please snap a picture or two once you get it fixed |
clow |
Sep 22 2010, 03:23 PM
Will do once the new piece is made! So I have everything pretty much figured out except the gas pedal bolts. Are they 2 studs that stick up from the floor?
jsayre914 |
Sep 22 2010, 03:29 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Will do once the new piece is made! So I have everything pretty much figured out except the gas pedal bolts. Are they 2 studs that stick up from the floor? Yup, i just pulled mine out the other day, it was kinda krusty (IMG:style_emoticons/default/sad.gif) Attached image(s) |
dlee6204 |
Sep 22 2010, 03:37 PM
QUOTE So I have everything pretty much figured out except the gas pedal bolts. Are they 2 studs that stick up from the floor? The gas pedal itself is attached with two bolts. The pedal cluster however is attached by studs in the floor. |
Lo-Fi Version | Time is now: 21st May 2024 - 09:24 AM |
