914 Seat restraints, How do you guys do it? |
avidfanjpl |
Sep 22 2010, 12:26 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I got dinged on my seatbelt for AX. The good news is that we do several annual high speed events, and I do want to have a 5 or 6 point in the car.
Anyone know how to put in a Simpson 5 point into a 914? How do I do the top belts and the submarine belt bolt mounts? Sizes? Bolt or weld? Any and all help appreciated. In a black car, should I do black for looks, red so they can see them? Silver might be nice. Blue, well, I don't think so. Muchas in advance! John (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
Mike Bellis |
Sep 22 2010, 12:59 PM
I run dual seatbelts. Stock retractable and a 5 point. 5 point is bolted through the fire wall and to the floor in front of the seat. Also use the stock lower rear mounting holes. I switch between belts as my driving or road conditions change.
DanT |
Sep 22 2010, 01:03 PM
or you can use a bolt in harness bar for the shoulder belts and eyes screwed into the stock lap belt locations so you can clip in and out the lap belt portion of the harnesses.
also the 6pt can also be clipped into the lap belt location and then you sit on the two straps and bring them up to the lap belt... this method does not require any additional holes to be drilled into your 914....just using stock belt locations. |
race914 |
Sep 22 2010, 01:14 PM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
There is a harness bar that bolts to the existing shoulder belt locations.
Here's a link to one that is available. Not a good pic since it's a 911 but gives you the idea. Price seems kinda crazy too since it is basically a steel tube with plates on each end. http://www.automotion.com/weltmeister-harn...or-porsche.html Food for thought anyway |
campbellcj |
Sep 22 2010, 11:08 PM
I would strongly suggest reading the rules for the sanctioning bodies and types of events you will be doing. Specifically, a minimal setup that will pass tech for a local autocross or DE may not pass for regional/national events, and certainly will not pass for competitive track events. Of course passing tech is really a secondary goal - the primary one is keeping you safe. (IMG:style_emoticons/default/smile.gif)
avidfanjpl |
Sep 22 2010, 11:38 PM
Thanks all for the comments!
I know the local and regional rules now. I looked them up. May be able to get approved for the bar, but if not, then my bodywork guy knows how to put eyes into the car and do the 6 point. I am looking at 3 manufacturers. Please recommend for me! Simpson is all I have looked at. John |
ellisor3 |
Sep 23 2010, 06:19 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
sean_v8_914 |
Sep 23 2010, 07:19 AM
avidfanjpl |
Sep 23 2010, 11:11 AM
Wow!
Thanks for all the stuff from all of you! I think I like the bars, but have to find out what PCA and PCA OCR will accept. Also, that book on mounting from Sean is COOL! The same company was also recommended to me by the Tech Mgr at PCA OCR. Still can't spell it without looking! S-C-H-R-O-T-H THANKS ALL! John |
Andyrew |
Sep 23 2010, 11:15 AM
I highly recomend using a bar in any case as it will prevent the harness (when mounted to the firewall) from compressing your spine. I have mine mounted to the firewall and up and over the bar.
ChrisFoley |
Sep 23 2010, 11:30 AM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I don't like the concept of harness bars in general. They often aren't sturdy enough for the application IMO.
Keep in mind that stock seats and 5pt harnesses are mutually incompatible in all the rules I've read for on-track driving. PCA DE rules require a seat built specifically for harnesses when they're installed. Modding a stock seat to comply with the shoulder harness requirements is not acceptable. |
PeeGreen 914 |
Sep 23 2010, 11:32 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I highly recomend using a bar in any case as it will prevent the harness (when mounted to the firewall) from compressing your spine. I have mine mounted to the firewall and up and over the bar. (IMG:style_emoticons/default/confused24.gif) |
bmtrnavsky |
Sep 23 2010, 12:20 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
Not to Hijack your thread, but still on topic...
I need some new seatbelts and was thinking of installing something like this in my car with stock seats. Will this pass tech at the local PCA autocross? DO you guys think it is safe for commuting etc? I don't want to dump $300 into something I cant use or isn't safe. |
6freak |
Sep 23 2010, 12:30 PM
I got dinged on my seatbelt for AX. The good news is that we do several annual high speed events, and I do want to have a 5 or 6 point in the car. Anyone know how to put in a Simpson 5 point into a 914? How do I do the top belts and the submarine belt bolt mounts? Sizes? Bolt or weld? Any and all help appreciated. In a black car, should I do black for looks, red so they can see them? Silver might be nice. Blue, well, I don't think so. Muchas in advance! John (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) what did they ding ya for ?was it operational?......and remember what you do to the drivers side you must do to the passanger side.that rule just introduced maybe 2 years ago .....those are PCA rules ....good luck |
bmtrnavsky |
Sep 23 2010, 05:40 PM
ChrisFoley |
Sep 23 2010, 07:00 PM
I don't want to dump $300 into something I cant use or isn't safe. If you use a stock type seat that has no hole for the shoulder harnesses it isn't safe. If you have an appropriate seat I wouldn't be afraid to use those in a street/autocross car. I have 5 point harnesses in my street 914 and I use them as a 3 point harness with a stock seat. If I take the car to the track, I'll have to install race seats to use the 5 points. |
GaroldShaffer |
Sep 23 2010, 09:25 PM
what did they ding ya for ?was it operational?......and remember what you do to the drivers side you must do to the passanger side.that rule just introduced maybe 2 years ago .....those are PCA rules ....good luck I have the same question. I have yet to see an operational stock seatbelt not pass tech at any SCCA event I have attened. |
campbellcj |
Sep 23 2010, 10:25 PM
Are you thinking about a cage or rollbar? Do you still have the stock backpad and plan to keep it? Will you be doing stock (or stock-improved/prepared) types of autox or DE events, or going farther into mods and maybe trying TT or cup race stuff? Those are other factors in figuring out the best way to set up the car in terms of safety gear. It sucks to have to redo stuff later if you can avoid it.
qa1142 |
Sep 24 2010, 04:34 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
So I have GTS LeMans seats and a (to be installed) Weltmeister harness bar
I would like to keep back pad and not drill firewall This is AutoX and DE / track day car NOT full race side by side stuff... So wrap-around installation will fail inspection? (IMG:style_emoticons/default/confused24.gif) Can someone with PCA experience pipe in? |
GeorgeRud |
Sep 24 2010, 08:06 AM
The PCA seems to have different rules for different events. A low-speed autocross doesn't require anything more than the stock seat belts, but as the speeds increase, so do the requirements.
You can find the current Chicago PCA requirements on their website. As others have said, it really depends on the sanctioning body's requirements. Read the rules and you should be good. From a safety standpoint, a 6 point harness, proper seat, fire suppression system, firesuit, and Hans Device are all great and should be used. Just depends on what you really want to do with the car. |
Lo-Fi Version | Time is now: 20th May 2024 - 10:45 PM |
