Side Mirror question |
carr914 |
Sep 23 2010, 08:17 AM
Racer from Birth Group: Members Posts: 118,721 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I couldn't find it, but I know there was a thread about locating & installing a passenger side mirror without screwing up existing paint, etc
Anybody have it saved? TC. |
Socalandy |
Sep 23 2010, 08:30 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
Dont have it saved but if you take off your door pannel and look inside you'll see the threaded holes. drill up thru them but select the right bit size and drill strait or you'll take out the threads.
AZ914 |
Sep 23 2010, 09:26 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
There is a tech article on the Pelican site:
http://www.pelicanparts.com/techarticles/9...ight_mirror.htm |
Tom_T |
Sep 23 2010, 12:18 PM
TC - it's also in Paternie's 914/914-6 book - although they recco'd using a puch up to locate then drill down from the top, which should be easier than fighting with the inner framework & window/regulator mech./etc. to stay straight, then make sure to treat with Wurth Zinc Rich Primer or something to prevent rust (somewhat anyhoo).
Although I have the earlier cover version, as may you (sorry, I can't find that pic offhand). |
aircooledtechguy |
Sep 23 2010, 01:08 PM
I recently did this on mine. I lightly punched it from the bottom. Then re-punched it from the top. Covered the area with masking tape to support the paint and protect the area. Then drilled small pilot holes. Then used a fine burr to slowly and carefully enlarge the holes until I could thread a M6X1.0 tap into the hole, cleaning out the factory threaded fastener below. Pealed the tape back over itself so the paint wouldn't lift or crack and mounted the new mirror.
Root_Werks |
Sep 23 2010, 02:39 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
On my 75', the holes were in the same spot as the drivers side. Just measured and drilled a pilot hole, then stepped up bit sizes being careful not to drill into the threads. Just don't stand on the drill.
Took maybe 15 minutes from start the finish, lined up perfect. |
Drums66 |
Sep 23 2010, 03:31 PM
Dont have it saved but if you take off your door pannel and look inside you'll see the threaded holes. drill up thru them but select the right bit size and drill strait or you'll take out the threads. ...Right, they should be there dit,dit,ditto (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/bye1.gif) |
rfuerst911sc |
Sep 23 2010, 03:37 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Tc take a spring loaded center punch and feel around for the nuts that are already in the door. The punch almost self centers and is much easier to use in tight space. Once you have the two holes marked reverse punch them from the top. I started with a small bit maybe a 1/16 to make the first holes. Then just slowly keep going bigger. This worked perfect on mine.
carr914 |
Sep 23 2010, 06:48 PM
Lo-Fi Version | Time is now: 21st May 2024 - 12:28 AM |
