Heat Flapper Valve Connection, How does the cable connect? |
rwilner |
Sep 24 2010, 06:58 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
So I finally got my heat back on the car last night, but I'm unclear how to connect the little mechanical cable to the flapper valve.
It looks like a barrel bolt or something is missing? Where can I get the correct fastener -- is something available at the hardware store? Thanks! Rich |
type47 |
Sep 24 2010, 07:03 AM
A barrel bolt which I don't think you'll find at the hardware store.
Wow! $10 at Pelican... (IMG:style_emoticons/default/dry.gif) |
rwilner |
Sep 24 2010, 08:12 AM
Jim
Is that bold threaded at one end to accept a screw, which presses against the cable end? Trying to envsion how it works. thx Rich |
tradisrad |
Sep 24 2010, 08:19 AM
the cable goes through the hole in the middle and the screw (missing in pic) goes in from the end. similar to the throttle cable (maybe same part)
rwilner |
Sep 24 2010, 08:28 AM
slu234 |
Sep 24 2010, 08:34 AM
Member Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region |
the cable goes through the hole in the middle and the screw (missing in pic) goes in from the end. similar to the throttle cable (maybe same part) That's what i figured. Anyone have an extra one??? You can get them at the car parts store (Advance, AutoZone). I believe that they were in a box of 4 and labeled as accelerator cable connector (not sure why you would need four of them) (IMG:style_emoticons/default/confused24.gif) Brian |
Tom_T |
Sep 24 2010, 12:00 PM
Common VW part also, you'll see them for much less at VW suppliers - both barrel nut & screw, or at the usual sources SMC, AA, GPR?, PP/Automotion, TC'sGarage, & yes Peli - as well as on TheSamba, evil-bay, etc.
$10 as a "Porsche" part vs. something like $2 for the "VW" part - nut/screw - or whatever $'s at FLAPS (IMG:style_emoticons/default/idea.gif) |
rwilner |
Sep 24 2010, 12:44 PM
Common VW part also, you'll see them for much less at VW suppliers - both barrel nut & screw, or at the usual sources SMC, AA, GPR?, PP/Automotion, TC'sGarage, & yes Peli - as well as on TheSamba, evil-bay, etc. $10 as a "Porsche" part vs. something like $2 for the "VW" part - nut/screw - or whatever $'s at FLAPS (IMG:style_emoticons/default/idea.gif) Going to try NAPA on the way home. Wish me luck |
bandjoey |
Sep 24 2010, 04:49 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Autozone has about 2-3 sizes in a bag for a few $'s.
rwilner |
Sep 24 2010, 05:19 PM
Lo-Fi Version | Time is now: 17th May 2024 - 09:35 AM |
