are they suppose to be there |
bigvag |
Sep 25 2010, 10:06 PM
Member Group: Members Posts: 50 Joined: 24-August 09 From: Ohio Member No.: 10,719 Region Association: None |
Removed the back swing arms to clean and paint. I took off the drivers side and everything look normal. I took off the pass. side and the three bolts that hold in the cup looking thingy(yeah technical) its the piece that bolt to the piece that is welded to the longs and it bolt to the outer half of the 22mm bolt that hold the swing arm. Anyway the drivers side didn't have any spacer in it but the passenger side had 3 spacers between the cup thingy and the part that welds to the longs. Is this normal. If a pic is needed let me know. The spacers have the same pattern as the 3 15mm bolt that hold the cup thingy to the part that is welded. Ok enough rambling I'm drunk.
bdstone914 |
Sep 25 2010, 10:10 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Removed the back swing arms to clean and paint. I took off the drivers side and everything look normal. I took off the pass. side and the three bolts that hold in the cup looking thingy(yeah technical) its the piece that bolt to the piece that is welded to the longs and it bolt to the outer half of the 22mm bolt that hold the swing arm. Anyway the drivers side didn't have any spacer in it but the passenger side had 3 spacers between the cup thingy and the part that welds to the longs. Is this normal. If a pic is needed let me know. The spacers have the same pattern as the 3 15mm bolt that hold the cup thingy to the part that is welded. Ok enough rambling I'm drunk. Those spacers are there to set the rear alignment on the car. Keep them as you will need them. |
Lennies914 |
Sep 25 2010, 10:11 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Those are the alignment shim thingys. (IMG:style_emoticons/default/beer.gif) Normal
JamesM |
Sep 25 2010, 10:13 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Removed the back swing arms to clean and paint. I took off the drivers side and everything look normal. I took off the pass. side and the three bolts that hold in the cup looking thingy(yeah technical) its the piece that bolt to the piece that is welded to the longs and it bolt to the outer half of the 22mm bolt that hold the swing arm. Anyway the drivers side didn't have any spacer in it but the passenger side had 3 spacers between the cup thingy and the part that welds to the longs. Is this normal. If a pic is needed let me know. The spacers have the same pattern as the 3 15mm bolt that hold the cup thingy to the part that is welded. Ok enough rambling I'm drunk. Technical terms and booze do not mix.... I am going to guess you are talking about the rear alignment shims? |
JFJ914 |
Sep 26 2010, 07:32 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Three shims are fine.
bigvag |
Sep 26 2010, 09:07 AM
Removed the back swing arms to clean and paint. I took off the drivers side and everything look normal. I took off the pass. side and the three bolts that hold in the cup looking thingy(yeah technical) its the piece that bolt to the piece that is welded to the longs and it bolt to the outer half of the 22mm bolt that hold the swing arm. Anyway the drivers side didn't have any spacer in it but the passenger side had 3 spacers between the cup thingy and the part that welds to the longs. Is this normal. If a pic is needed let me know. The spacers have the same pattern as the 3 15mm bolt that hold the cup thingy to the part that is welded. Ok enough rambling I'm drunk. Technical terms and booze do not mix.... I am going to guess you are talking about the rear alignment shims? You got that right. Thanks guys for the replies. |
underthetire |
Sep 26 2010, 09:29 AM
Whats not normal is to have none in the drivers side. And how thick are the shims, and are they the right ones. I wouldn't say it normal until you post pics, my fear is some PO put them in the passenger side to compensate for a console collapsing.
ConeDodger |
Sep 26 2010, 09:46 AM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Removed the back swing arms to clean and paint. I took off the drivers side and everything look normal. I took off the pass. side and the three bolts that hold in the cup looking thingy(yeah technical) its the piece that bolt to the piece that is welded to the longs and it bolt to the outer half of the 22mm bolt that hold the swing arm. Anyway the drivers side didn't have any spacer in it but the passenger side had 3 spacers between the cup thingy and the part that welds to the longs. Is this normal. If a pic is needed let me know. The spacers have the same pattern as the 3 15mm bolt that hold the cup thingy to the part that is welded. Ok enough rambling I'm drunk. (IMG:style_emoticons/default/drunk.gif) Being drunk isn't bad - unless you're a goldfish... in a frat house... During rush week! (IMG:style_emoticons/default/blink.gif) Then being drunk is pretty much fatal unless you can make the pledge puke. (IMG:style_emoticons/default/barf.gif) Definitely alignment shims. |
underthetire |
Sep 26 2010, 10:21 AM
Tom_T |
Sep 26 2010, 01:49 PM
Whats not normal is to have none in the drivers side. And how thick are the shims, and are they the right ones. I wouldn't say it normal until you post pics, my fear is some PO put them in the passenger side to compensate for a console collapsing. ... or to compensate for a bent unibody from an accident - did it "crab" - i.e.: drive a bit sideways when going straight, when viewed from front or rear in a leading or trailing car? If so, then you'll need to get it onto a Cellette Bench to pull it straight & true. Also btw - I prefer "doo-hicky"! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 01:57 AM |
