Autoatlanta aftermarket fuel injection kit |
Porschef |
Sep 26 2010, 07:36 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Has anyone used this?
Thanks, Joe |
qa1142 |
Sep 26 2010, 07:48 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
(IMG:style_emoticons/default/poke.gif) Where is the link?
ripper911 |
Sep 26 2010, 07:54 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Is this the one?
Fuel injection kit Looks promising... I thought about that kit when I got my new engine. but I got 40 ida's for budgetary reasons... maybe some day. |
76-914 |
Sep 26 2010, 08:05 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is that plastic fuel filter, in the pic, under 30 psi constant pressure?
OmaPossu |
Sep 26 2010, 08:26 AM
Member Group: Members Posts: 241 Joined: 4-October 09 From: Finland Member No.: 10,886 Region Association: Scandinavia |
Is this set for 1.7, 1.8 or 2.0l engines? Stock 90hp?
race914 |
Sep 26 2010, 08:28 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Porschef |
Sep 26 2010, 08:37 AM
Yes, Ripper, that's the one.
ConeDodger |
Sep 26 2010, 08:51 AM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have not looked at it either in the catalog or in person, but a local shop here in Sac, IPB Autosport removed one a year ago to put carbs on a 914 because neither they or the cars owner could make it run right.
swl |
Sep 26 2010, 09:03 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Certainly looks like the CB intakes. Looks like George has mated this to injectors and and crankfire for a turn key solution. He shows it for all years so he must be differentiating by injectors and map. A little pricey for sure but a nice solution for an elderly DJet. There are so many NLA components now that it seems to be either carbs or aftermarket FI. A question for the head gurus. Is the plenum really the constriction on our cars? Seems to me that that no matter how much air you blow through the plenum at some point you are going to be restricted by the heads. Is there really that much constriction in the plenum that you could get big gains without doing the heads/cams? |
AndyB |
Sep 26 2010, 09:10 AM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
(IMG:style_emoticons/default/agree.gif) Enquiring minds want to know (IMG:style_emoticons/default/biggrin.gif)
charliew |
Sep 26 2010, 09:19 AM
THe way I read it the plenum is the biggest restrictor or how does the itbs work so much better on stock heads? Itb's will always flow more air than long tube intake manifolds.
Mark Henry |
Sep 26 2010, 10:37 AM
The TB's are CB but that coil pack is SDS. I saw the the dizzy and it had SDS crank sensors. I guessing it`s mostly an SDS system.
orange914 |
Sep 26 2010, 10:44 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Is that plastic fuel filter, in the pic, under 30 psi constant pressure? i don't even see hose clamps on it. surprisingly cheasy advertising to get my $3500 (IMG:style_emoticons/default/stirthepot.gif) |
Mark Henry |
A stock engine going from 90hp to 125hp just because you add PEFI is total bullshit!
(IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/bs.gif) There is no such thing as a "crank fire distributor". It's either "crank fire" or "distributor". |
underthetire |
Sep 26 2010, 10:50 AM
Really? I can't get 50% more power with just FI ? How about if I add the fuel magnet and intake tornado? Maybe the electric turbo? (IMG:style_emoticons/default/teef.gif)
Mark Henry |
Sep 26 2010, 11:01 AM
Really? I can't get 50% more power with just FI ? How about if I add the fuel magnet and intake tornado? Maybe the electric turbo? (IMG:style_emoticons/default/teef.gif) Stickers add 50hp. (IMG:style_emoticons/default/rolleyes.gif) |
BMXerror |
Sep 26 2010, 11:27 AM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
I would rather just pay $2000 for the real SDS system.... oh, wait. I already did. (IMG:style_emoticons/default/biggrin.gif)
Once it's installed I'll see what difference good fuel control alone makes on the stock plenum, and then decide if I need to go bigger. But slapping injectors into Carb throttle bodies seems like a pretty cheesy solution. Mark D. The TB's are CB but that coil pack is SDS. I saw the the dizzy and it had SDS crank sensors. I guessing it`s mostly an SDS system. |
underthetire |
Sep 26 2010, 11:39 AM
The throttle bodies will help if you have enough motor to use them. I've seen Suzuki GSXR bodies mounted to weber intakes before. For the average guy i'm not sure they would help. Guess a dyno would be the only way to know for sure.
JFJ914 |
Sep 26 2010, 12:33 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
A question for the head gurus. Is the plenum really the constriction on our cars? Seems to me that that no matter how much air you blow through the plenum at some point you are going to be restricted by the heads. Is there really that much constriction in the plenum that you could get big gains without doing the heads/cams? The exhaust is the restriction. Work on that first. |
Jake Raby |
Sep 26 2010, 03:03 PM
Plenum volumes are critical to RPM range.. I have used a stock 2.0 plenum on 2270cc engines up to 145HP,above that its pretty worthless. The 2.0 Bus plenum has proven to be more well designed to me, in back to back comparisons on the same engine.
With a plenum based system camshaft specifics are absolutely critical at low speed and idle. Cams set up for a very high manifold pressure will give the best vacuum signature thats necessary for a MAP based common plenum to be effective and tunable. Generally the lobe separation is the key.. That said, George's system is SDS driven with some CB hardware. I almost had a chance to tune one for him a month or so ago on my chassis dyno. BTW- Its not so much a "restriction" or "constriction" as much as being less than optimum for certain RPM ranges. I just finished the revitalization of the engine for my 912E. Its a 2056 that is being built for MPG, smooth running and 90 miles per day commuting. I optimized this engine for air conditioning and to utilize a stock 2.0 common plenum. I am using a new system that Electromotive has developed for us that is generally used on motorcycle engines for my PEFI solution. This coupled to the RAT/ Extrudabody throttle body and my seriously modified fuel delivery arrangement that utilizes a fuel distributor rather than fuel rails should fit the bill quite well. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1095-1285535649.1.jpg) I changed the cam in this engine from a RAT 9530 with a 105* lobe separation to the same cam with a 112* lobe separation. The previous version supplied me with 160K miles of trouble free, reliable performance. It was worn but had much more life in it when I tore into it as you can see here. http://www.aircooledtechnology.com/index.p...&Itemid=112 This post has been edited by Jake Raby: Sep 26 2010, 03:14 PM |
Lo-Fi Version | Time is now: 20th May 2024 - 09:02 PM |
