shadek oil pump clearances/gaslet, next motor assembly question |
brant |
Sep 26 2010, 12:46 PM
boy I'm feeling old
3-4 years ago I knew the answer to this and even put the motor together but now I'm assembling and don't remember the answer I'm installing my Shadek (30 I think) oil pump I have Jakes studs, and Jakes cover plate the pump was in the motor previously (with a different cam) the pump has been checked for clearance of the cam-gear bolts, as well as the pump nose to cam end. question is about gaskets and oil-gear clearance new gasket kit has a stock gasket to put between block and pump what do I use for a gasket between the exterior pump face and the cover (I know this measurement is critical for the pump to work correctly/tolerances) I looked last night on Jakes site but it was down for maintenance.... I'll check again now to see what he sells. thanks in advance everyone and thanks for all the help you've already given too. brant |
bam914 |
Sep 26 2010, 02:06 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
Check the gear to cover clearance by bolting the cover on to the pump. If it spins free then do not use a gasket. Apply Loctite 518 to the cover. This will give you the best oil pressure. Also make sure the cover is flat.
Jake Raby |
Sep 26 2010, 02:54 PM
We haven't sold an oil pump in over a year. The quality went to hell on the Schadek pumps and we can't make enough of the billet pumps to do more than satisfy our own demands for engine production.
I like .001 total gear end play, then use no gasket as Blake mentions above. |
brant |
Sep 26 2010, 03:08 PM
Thanks again to both of you
its a 5 year old shadeck with very low mileage (I put 76miles on the motor when I built it 3-4 years ago... and its been sitting indoors since) I hope the quality is good enough... I did have to clearance the back of the housing for the new 9590 cam. I bought the cover and studs from you Jake, and at that time you weren't recommending against the shadeck... at least not that I remember brant |
Jake Raby |
Sep 26 2010, 03:16 PM
The Schadek went to hell about 18 months ago.. If its older than that you should be fine.
I just reused the Schedk in my old 912E engine, it was a Schadek from 2002. After 160K it was good enough to be reused. |
realred914 |
Sep 27 2010, 10:44 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
the flat steel cover that comes with teh pump is not flat, nor will it remian flat when torqued down (dial indicator will confirm this) what you need to get is the stock VW pump xcovers that have the bent up raised edges, this will prevent warping of the cover when it is torqued down. the flat plate covers bow in the middle when tightened down, the bow is as much as .007 inch or so well with in the relm of effecting oil pressure. the stock VW covers have the raised edges which stiffens the plate. get the stock cover to be sure it remians flat.
Mark Henry |
Sep 27 2010, 11:34 AM
Schadek never came with a flat steel cover, only melling. Jake doesn't sell a flat steel cover (or melling pumps).
VaccaRabite |
Sep 27 2010, 12:34 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I thought you had to modify a T1 pump cover for the HD Shadeck in a T4.
Thats what I did with mine anyway. Zach |
Lo-Fi Version | Time is now: 17th May 2024 - 09:08 AM |
