hard start |
hard start |
oldschool |
Sep 26 2010, 05:18 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
This is the first time this has happen? after a long run I stop to get a drink,and it seem to be a bit harder to start, It was hot that day, Today I was out riding and as I was ready to put her in the garage, It did it again (IMG:style_emoticons/default/confused24.gif) So here it is 1973 1.7 org d fI
today it was over 100 so do you think vapor? |
Tom |
Sep 26 2010, 07:26 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
If you mean it is turning over OK, but doesn't want to fire, that has been discussed here. Do a search and you will see. I tried, but my search skills are obviously no good. I get x thousands of answers!??
Basically it is a heat problem "fooling" the ecu to be extra rich. Tom |
oldschool |
Sep 26 2010, 08:53 PM
This is the first time this has happen? after a long run I stop to get a drink,and it seem to be a bit harder to start, It was hot that day, Today I was out riding and as I was ready to put her in the garage, It did it again (IMG:style_emoticons/default/confused24.gif) So here it is 1973 1.7 org d fI today it was over 100 so do you think vapor? Old school, what do you mean by hard to start? Does the starter turn slowly or not at all like the typical 'hot start' problem or does the engine turn over at the normal speed but doesn't fire? I am sure the FI gurus can pitch in on this one |
jim_hoyland |
Sep 26 2010, 09:16 PM
Get that VIN ? Group: Members Posts: 9,299 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Some year models you're supposed to gie ut gas when starting, IIRC
oldschool |
Sep 26 2010, 11:08 PM
I never had that happen before, It always would fire right up. (IMG:style_emoticons/default/confused24.gif)
Tom_T |
Sep 27 2010, 01:40 AM
This is the first time this has happen? after a long run I stop to get a drink,and it seem to be a bit harder to start, It was hot that day, Today I was out riding and as I was ready to put her in the garage, It did it again (IMG:style_emoticons/default/confused24.gif) So here it is 1973 1.7 org d fI today it was over 100 so do you think vapor? Old school, what do you mean by hard to start? Does the starter turn slowly or not at all like the typical 'hot start' problem or does the engine turn over at the normal speed but doesn't fire? I am sure the FI gurus can pitch in on this one Jaimie - the owners' manual says to put the pedal to the floor & hold it while cranking until the motor catches (or a reasonable time cranking then retry) & release after started. That's D-jet SOP per Porsche. If your fuel pump is still in the rear/engine compartment, then it's well worthwhile to get the reloc. kit (AA & ??) & move it up in the notch behind the steering rack cover per the factory service bulletin. I had mine done back in 78 after sitting it out at the Blythe Denny's coming back from summer water skiing, & no vapor lock problems after that! |
Tom |
Sep 27 2010, 08:14 AM
mburkhart |
Sep 28 2010, 09:09 AM
Member Group: Members Posts: 112 Joined: 3-July 05 From: Chester, MD Member No.: 4,364 Region Association: MidAtlantic Region |
QUOTE If your fuel pump is still in the rear/engine compartment, then it's well worthwhile to get the reloc. kit (AA & ??) & move it up in the notch behind the steering rack cover per the factory service bulletin. I had mine done back in 78 after sitting it out at the Blythe Denny's coming back from summer water skiing, & no vapor lock problems after that! So you're a believer in the vapor lock issue + fix? My car stalled this summer on a hot day, but there appears to be some debate on these forums about whether vapor lock is a real issue or not. I'm not sure what to believe at this point. |
bmtrnavsky |
Sep 28 2010, 06:41 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
QUOTE If your fuel pump is still in the rear/engine compartment, then it's well worthwhile to get the reloc. kit (AA & ??) & move it up in the notch behind the steering rack cover per the factory service bulletin. I had mine done back in 78 after sitting it out at the Blythe Denny's coming back from summer water skiing, & no vapor lock problems after that! So you're a believer in the vapor lock issue + fix? My car stalled this summer on a hot day, but there appears to be some debate on these forums about whether vapor lock is a real issue or not. I'm not sure what to believe at this point. I have the exact same symptom as you... Get in in the morning and it fires right up. Motor 10 minutes down the road to the gas station, shut it down, fule up and it cranks over hard and fast for 30-45 seconds then slowly comes to life. Then it runs but wants to die for about 2-3 minutes. I have my fuel pump in the front and that didn't help, but today when I fueled up I pressed the gas pedal to the floor and held it before I started cranking the motor and it fired up just like it does cold. (IMG:style_emoticons/default/piratenanner.gif) |
oldschool |
Sep 28 2010, 07:16 PM
QUOTE If your fuel pump is still in the rear/engine compartment, then it's well worthwhile to get the reloc. kit (AA & ??) & move it up in the notch behind the steering rack cover per the factory service bulletin. I had mine done back in 78 after sitting it out at the Blythe Denny's coming back from summer water skiing, & no vapor lock problems after that! So you're a believer in the vapor lock issue + fix? My car stalled this summer on a hot day, but there appears to be some debate on these forums about whether vapor lock is a real issue or not. I'm not sure what to believe at this point. I have the exact same symptom as you... Get in in the morning and it fires right up. Motor 10 minutes down the road to the gas station, shut it down, fule up and it cranks over hard and fast for 30-45 seconds then slowly comes to life. Then it runs but wants to die for about 2-3 minutes. I have my fuel pump in the front and that didn't help, but today when I fueled up I pressed the gas pedal to the floor and held it before I started cranking the motor and it fired up just like it does cold. (IMG:style_emoticons/default/piratenanner.gif) cool with this 110 heat i will give it a try. |
Jeffs9146 |
Sep 28 2010, 08:31 PM
FI or Carbed?
If FI then it's the CHTS!! |
Cap'n Krusty |
Sep 28 2010, 08:55 PM
Lo-Fi Version | Time is now: 17th May 2024 - 12:59 PM |
