QUOTE(mburkhart @ Sep 28 2010, 08:09 AM)
If your fuel pump is still in the rear/engine compartment, then it's well worthwhile to get the reloc. kit (AA & ??) & move it up in the notch behind the steering rack cover per the factory service bulletin. I had mine done back in 78 after sitting it out at the Blythe Denny's coming back from summer water skiing, & no vapor lock problems after that!
So you're a believer in the vapor lock issue + fix? My car stalled this summer on a hot day, but there appears to be some debate on these forums about whether vapor lock is a real issue or not. I'm not sure what to believe at this point.
I have the exact same symptom as you... Get in in the morning and it fires right up. Motor 10 minutes down the road to the gas station, shut it down, fule up and it cranks over hard and fast for 30-45 seconds then slowly comes to life. Then it runs but wants to die for about 2-3 minutes.
I have my fuel pump in the front and that didn't help, but today when I fueled up I pressed the gas pedal to the floor and held it before I started cranking the motor and it fired up just like it does cold.
