Sound mat, foil faced sound deadener mat |
IronHillRestorations |
Sep 27 2010, 09:49 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
B-Quiet Brown Bread sound deadener mat. Foil faced, flexible, and easy to install, will hold paint. 2' wide roll. $2 square foot plus actual shipping. Limited amount left. PM me or email a914man@netease.net or call my main business (Q Snap) at 800-867-4712
brown bread installed in a Nissan. Sorry I don't have a install pic from a 914 |
pilothyer |
Sep 27 2010, 10:07 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Would this material be suitable for use on the firewall inside the engine compartment?
Sep 27 2010, 11:13 AM
Mark Henry |
Sep 28 2010, 07:22 AM
Would this material be suitable for use on the firewall inside the engine compartment? I can tell you for sure, BTDT, I've tried it (on my '67 bus)...No, the butyl will semi-melt and it will fall off. Daily driving it will release in about 3-6 weeks. Good product, it's just not meant for the engine bay. Should be fine on the interior side of the firewall. |
pilothyer |
Sep 28 2010, 07:37 AM
Thanks for the replies, I thought for sure I had found an alternative to that giant sponge for the firewall insulation in the engine bay.
Sep 28 2010, 09:31 AM
B-Quiet does make a multi layered foam sound mat that I've used for the firewall, but I also used a high quality mylar foil tape to seal the edges. For that install I used cheeshead screws (just like the engine tin screws) and large fender washers to mechanically hold the sound mat, which also had a peel off self adhesive.
Lo-Fi Version | Time is now: 9th May 2024 - 09:52 PM |
