Full Flow Engine Mount, For FF Gene Berg covers and 30mm+ pumps |
Mark Henry |
Apr 18 2004, 12:32 PM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler.
Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $90. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $10 with mount. PM me for shipping details Attached image(s) |
race914 |
Feb 7 2009, 07:40 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent on the 5th with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg |
race914 |
Feb 9 2009, 12:30 PM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg Email sent |
race914 |
Feb 12 2009, 09:20 AM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg Email sent (IMG:style_emoticons/default/icon_bump.gif) |
race914 |
Feb 20 2009, 08:41 AM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg Email sent (IMG:style_emoticons/default/icon_bump.gif) Anyone in communication with Mark? Hope he's ok. |
race914 |
Feb 23 2009, 08:32 AM
Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler. Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings. Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it. Will only work with the 30mm (or larger) pump. $45. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $5. PM me for shipping details Mark, I'd like to buy one of your full flow engine mounts. PM sent with shipping location. Let me know the total and your preferred payment method. Thanks for producing these! Greg Email sent (IMG:style_emoticons/default/icon_bump.gif) Anyone in communication with Mark? Hope he's ok. Mark, I'm still trying to contact you. Not sure if you've seen the replies to this thread so another PM & Email sent. If anyone else knows Mark and can point him to this thread and/or his PMs, I'd appreciate it! |
VaccaRabite |
Feb 26 2009, 12:35 PM
Mark recently had a death in the family and may be taking care of family obligations. Give him some time.
Zach |
race914 |
Mar 25 2009, 09:27 AM
Mark recently had a death in the family and may be taking care of family obligations. Give him some time. Zach (IMG:style_emoticons/default/icon_bump.gif) It's been over 6 weeks now... Just curious regarding my acceptance of this Vendor Offered item??? |
JazonJJordan |
Jul 4 2009, 10:01 AM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
Mark recently had a death in the family and may be taking care of family obligations. Give him some time. Zach I am sorry to hear of Mark's loss...(thank you passing the word~ Zach) (IMG:style_emoticons/default/huh.gif) |
Mark Henry |
Jul 17 2009, 10:34 AM
Sorry...
yep my brother Paul passed, My mom's has out lived every family member and friend, save me, and she and the kids are taking up much of my free time. I also had a winter/spring of kidney stones and I'm only now getting caught up a bit now. I don't have time to make this product right now and there will have to be a price increase. Takes me 2 hours to make each one. I`ll try to stock 2-3 mounts each year as of this fall if I can find the cores. If you guys want to do a group buy (say 10) then I could do a mini-run of them, could even get them power coated. I will drop the price to $50 + core, I will/would "drop" ship to each person for $6. BUT I deal with one person ONLY and I would need cores. That I would do right away. Thanks PS if it is really really really important that you get one right now PM me (as in engine going in this week...or I`m dead... kind of thing). |
Lo-Fi Version | Time is now: 10th May 2024 - 12:17 AM |
