Anyone who wants to run a plugged Type one 30mm pump with a Berg, Raby (or equivalent) FF cover, so that you can use a remote filter adaptor, oil T-stat, and cooler.
Gets rid of restrictive sandwich adaptors and the stock filter mount. More flow means better oil pressure for running those long lines to a front mounted cooler. Using a Gene Berg pressure relief cover (std cover shown) means you never have to worry about cooler blowouts even on the coldest mornings.
Fully gusseted, stronger than stock, bead blasted and painted black (the yellow was to make it show up in the pic) or raw so you can powder coat it.
Will only work with the 30mm (or larger) pump.
$90. (USD) + core, includes return postage. ($25. core charge) Stock filter mount delete plate an extra $10 with mount.
PM me for shipping details
