FS: 911/01 transmission, for the /6 conversion guys |
T H O M A S |
Sep 28 2010, 08:37 PM
Senior Member Group: Members Posts: 626 Joined: 1-August 03 From: Donaueschingen, Germany Member No.: 974 Region Association: None |
this is the spare transmission from the /6 i sold , 20k original miles 911/01 transmission( stored i a warehouse since 1971 from a 2.2t 911)flipped ring and pinion,converted to side shift,all new seals,stock gears A GA O V ZA,comes with clutch fork parts,new clutch cable,throttel bell crank parts for the /6 throttle cable and a used trow out bearing in good condtion( a new one is over $200)
the 911/01 allows you to use the 225 pull type clutch setup from 2.2 to 3.0 engines, i can take pictures on wed. if needed $1500+shipping or i can deliver to G&R swap meet |
Lo-Fi Version | Time is now: 12th May 2024 - 08:42 AM |
