this is the spare transmission from the /6 i sold , 20k original miles 911/01 transmission( stored i a warehouse since 1971 from a 2.2t 911)flipped ring and pinion,converted to side shift,all new seals,stock gears A GA O V ZA,comes with clutch fork parts,new clutch cable,throttel bell crank parts for the /6 throttle cable and a used trow out bearing in good condtion( a new one is over $200)
the 911/01 allows you to use the 225 pull type clutch setup from 2.2 to 3.0 engines,
i can take pictures on wed. if needed
$1500+shipping or i can deliver to G&R swap meet
