Electrical Question, found it, thanks to me |
76-914 |
Sep 29 2010, 07:06 PM
Well I've developed a sitiuation very similar to the recent "Parasitic battery drain" thread, including the bum meter. I've got a .2A draw and it's on one of the small red harnessed wires at the + batt post. Do they run thusly; 1 to 14 pin connector, 1 to 12 pin connector, 1 to the starter switch and 1 to the fuse panel under the dash???? I'm pretty sure it's the starter or starter switch because I still have a drain with all fuses pulled from fuse panel and the 2 fuses in the relay box. Also with all 4 relays and all plugs disconnected from the relay box. Input, suggestions. BTW, my batt grnd is shiney clean. I (IMG:style_emoticons/default/stromberg.gif) you not.
pcar916 |
Sep 30 2010, 03:34 PM
Big clock? This just happened to a friend on his truck and it turned out to be the alternator after a rebuild. Something was "wonky" inside. I had never seen that before.
Even if I have a slow current drain now I wouldn't know it 'cause the battery cut-off switch is turned off every time I get out of the car. I don't have a clock so it's not a problem. I would clean all of the other grounding points though, like the transaxle strap and the one on the firewall behind the driver. I wasn't having any problems with the car. But grounding gremlins annoy me enough that I ran a 10-gauge cable from the negative battery-terminal in the front trunk through the cockpit and into the rear of the car and tied together all of the grounding points to that... I even added one or two as I recall. Good Luck! |
76-914 |
Oct 2 2010, 04:13 PM
(IMG:style_emoticons/default/icon_bump.gif) I think I may have found it. First I isolated the 4 lg red wires which were bundeled. I was getting a .2a draw when these were connected to the + post. There was no draw on the starter side. Did I mention this began the day it got to 106 here? That was 3 days before it got to 113 in LA. You do the math. So this morning I hook everything back up except I used a terminal block to reconnect the previously bundeled wires and SOB; the draw is gone. (IMG:style_emoticons/default/WTF.gif) Now why in the Hell would that thing up and dissapear like a fart in the wind? Oh well! I crank the motor over and nothing. Then I remember I hadn't heard the FP run. Switch on; nutin. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/ar15.gif) After I regained my composure, I opened my copy of the FP flow chart and I traced it down to a faulty relay board. (IMG:style_emoticons/default/stromberg.gif) I hope that's it and not 4 other things.
silver74insocal |
Oct 2 2010, 04:47 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
(IMG:style_emoticons/default/cheer.gif) go Kent go!! glad to see you are still chasing down gremlins i hope to get back on track with mine soon. hopefully we'll be meeting up again at the g & r swap meet again. (IMG:style_emoticons/default/beerchug.gif) good luck and keep up the good fight. Dave
Lo-Fi Version | Time is now: 17th May 2024 - 05:01 PM |
