Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
The PO had the tank cleaned and resealed, but I'm puzzled by what's happening- the hose connection (charcoal canister, perhaps) by the fill was disconnected when I got the car. I assumed it had just been disconnected somehow and so I reconnected it. Just so happened that I had the car running in the driveway, checking some other stuff. Shortly thereafter, I noticed the fuel pump making a strange sound. I didn't know what to do, other than undo the last thing I did on the car. Turns out the tank has quite a bit of vacuum. I didn't realize it until after I had pulled the hose off, and started to hear the tank expand back into it's original shape. Removing the gas cap relieved even more pressure quickly. The pump then quieted, and all has been ok since.
Does this sound like a pinched return line? If so, would it cause a rich condition? Thanks in advance, Joe |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Tthe charcoal canister is just a smog thing.. return the fuel vapors back to the intake... Most people just leave it unplugged.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
That way they get those nasty fumes in the passenger compartment instead of the engine ....................................... Buncha huffers ....................
Yes, the return could be partially blocked and that would make it run rich if you're running FI. Check the fuel pressure. If it's way too high, run the return line into a can and see if it's still too high. If it's not, you've found the problem. Make sure the vapor hoses are clear, and that air flows through the can. Make sure the hoses are properly connected in the engine compartment. The Cap'n |
Lo-Fi Version | Time is now: 6th July 2025 - 05:34 AM |
