Need a "CV plate" and a shift rod.... help! |
jaybird840 |
Sep 30 2010, 06:30 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
After 2 1/2 years of converting my car to a six, I'm about ready for light off. I need one "CV plate" which is the little bracket that yokes two CV bolts together. Somebody has to have one in a bin somewhere.
Also, check your parts stashes as I may be in need of a shift rod for a side shift tranny. I boxed mine up and mailed it to Perry Kiehl over two weeks ago for him to modify it for a six install. USPS has "misplaced" it--unfortunately, it had new bushings in it. (IMG:style_emoticons/default/sad.gif) They are basically cores for Perry to work his magic on, so if you've got one that's bent, that's OK as long as the ends are undamaged. I'm down to the last few shillings in my project budget (that is several thousand $$ over-budget (IMG:style_emoticons/default/beerchug.gif) ), so be gentle. After 30 months, it's nearly time for Weber music!!!! -Jaybird |
tscrihfield |
Sep 30 2010, 07:06 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
After 2 1/2 years of converting my car to a six, I'm about ready for light off. I need one "CV plate" which is the little bracket that yokes two CV bolts together. Somebody has to have one in a bin somewhere. Also, check your parts stashes as I may be in need of a shift rod for a side shift tranny. I boxed mine up and mailed it to Perry Kiehl over two weeks ago for him to modify it for a six install. USPS has "misplaced" it--unfortunately, it had new bushings in it. (IMG:style_emoticons/default/sad.gif) They are basically cores for Perry to work his magic on, so if you've got one that's bent, that's OK as long as the ends are undamaged. I'm down to the last few shillings in my project budget (that is several thousand $$ over-budget (IMG:style_emoticons/default/beerchug.gif) ), so be gentle. After 30 months, it's nearly time for Weber music!!!! -Jaybird PM'D |
914Sixer |
Sep 30 2010, 07:33 PM
I will be back in town Monday. I have all the cv joint plates you need. Send address and I will send one all the way from Boerne.
Lo-Fi Version | Time is now: 13th May 2024 - 11:01 AM |
