Best way to attack the rust?, trying to figure out the best order do rust repair |
kphimself |
Oct 5 2010, 07:21 PM
Member Group: Members Posts: 124 Joined: 6-September 10 From: VA Beach, VA /Fayetteville, NC Member No.: 12,146 Region Association: MidAtlantic Region |
So i got my car in the garage this evening and i plan starting on repairing my rust issues in the morning. My outer longs seem to be rusted badly about 2 to 3 inches on either side of the jack posts. The inner long seems to have a 6 inch rust hole along the bottom on each side just forward of the jack post. The floor pan is rusted badly along the drivers side and rear corner. I'm trying to find out is it best to repair the outer long first or cut away some of the old floor pan, repair the inner longs then replace the floor pan and do the outer longs? I will be putting a brace in from the upper hing to the seat belt bolt for support but i'm worried that cutting away too much at one time will cause the car to split in two.
hot_shoe914 |
Oct 5 2010, 09:00 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
So i got my car in the garage this evening and i plan starting on repairing my rust issues in the morning. My outer longs seem to be rusted badly about 2 to 3 inches on either side of the jack posts. The inner long seems to have a 6 inch rust hole along the bottom on each side just forward of the jack post. The floor pan is rusted badly along the drivers side and rear corner. I'm trying to find out is it best to repair the outer long first or cut away some of the old floor pan, repair the inner longs then replace the floor pan and do the outer longs? I will be putting a brace in from the upper hing to the seat belt bolt for support but i'm worried that cutting away too much at one time will cause the car to split in two. I believe the best way to attack rust in your part of the country is to arm yourself with Scotty B and go at it head on! (IMG:style_emoticons/default/sawzall-smiley.gif) |
PanelBilly |
Oct 6 2010, 12:55 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Dollar wise, I think you should look for another shell. Fun wise I say brace it and start cutting. I don't think it matters if you want to remove the bad pan area. Just keep the doors handy and keep checking that they line up
kphimself |
Oct 6 2010, 06:00 PM
I went ape shit on it today and its alot better then i thought, then inner longs are in really good shape except for a small area below the jack post. I think i'm going to brace it up and go at from the outside in then replace the floor pan. However i have never seen such shitty welding and so much seam sealer in all my life. This is the 4th vechical i have restored and it looks like they just slaped these things together and used seam sealer to cover up a lack of skill.
Lo-Fi Version | Time is now: 17th May 2024 - 04:34 PM |
