Relay board repair, How I did mine |
Bartlett 914 |
Oct 8 2010, 12:13 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have a relay board that was giving me grief. Several times the car would not start. Cleaning the fuse seemed to help but once in a great while the problem returned. The problem was the fuse holder. As these connections get dirty, they heat up. The problem in my case was aggravated by the use of the heater fan. This draws more current and made the problem of the fuse heating worse. I have some before and after pictures. You can see how the fuse holder is leaning back. If you look closer, you can see melted plastic where it is mounted. My solution was to install a new fuse holder. I recently installed an Engman fuse panel so now all my fuses will be the newer style. No more VW fuses! Te resin I used was Vagabond Model-cast 3521S black. This stuff flows like water and dries pretty fast. It is hard when cured and looks real nice. The biggest problem is the resin flowing through the board and leaking. I knew this would happen and I taped where I thought it would leak out. I missed the voltage regulator socket. It looked fine from the rear but it leaked real bad. I had quite a time sealing this up. If you do this, try epoxy first to seal where the pins come through.
Attached image(s) |
DTMLGND |
Dec 16 2018, 01:36 AM
Newbie Group: Members Posts: 32 Joined: 6-November 11 From: US Member No.: 13,756 Region Association: Southern California |
Hi! I just acquired my ā74 2.0 a few months ago and trying to get it started after sitting for possibly 2 years. Iām finding my fuel pump not coming on and upon testing circuits, only two of four injectors functioning. Flipped my board over and it looks like some melted. I chipped away all black epoxy and will proceed with soldering the rivets.
Lo-Fi Version | Time is now: 19th May 2024 - 05:40 AM |
