how to remove |
how to remove |
bigvag |
Oct 9 2010, 04:52 PM
Member Group: Members Posts: 50 Joined: 24-August 09 From: Ohio Member No.: 10,719 Region Association: None |
Ok how do you remove the bar that connects the front suspension. Its the one that runs in side the front truck underneith the gas tank. Maybe the torsion bar.
poorsche914 |
Oct 9 2010, 05:00 PM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Ok how do you remove the bar that connects the front suspension. Its the one that runs in side the front truck underneith the gas tank. Maybe the torsion bar. I believe you are talking about the anti-sway bar. Never removed one so can't help you there. (IMG:style_emoticons/default/unsure.gif) |
Mike Bellis |
Oct 9 2010, 05:01 PM
It's the sway bar and it slides out. Remove your wheel and anything in front of it. un blot the links and slide it out.
bigvag |
Oct 9 2010, 05:11 PM
Cap'n Krusty |
Oct 9 2010, 05:27 PM
Two ways. Remove the grommet and its cover, or use dish soap on the bar and yank it out.
The Cap'n |
bigvag |
Oct 9 2010, 05:31 PM
Two ways. Remove the grommet and its cover, or use dish soap on the bar and yank it out. The Cap'n i'll one up it and use k.y jelly. (IMG:style_emoticons/default/piratenanner.gif) |
BarberDave |
Oct 9 2010, 05:35 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Well, use what you have the most of, and use to using !!!!!!! Dave (IMG:style_emoticons/default/slap.gif) |
bigvag |
Oct 9 2010, 06:00 PM
I got it. They are a split bushing, you just need to use something (screw driver) to push the bushing out the back. but the dish soap did help by lubing the bushing.
Lo-Fi Version | Time is now: 17th May 2024 - 03:29 PM |
