Brake Caliper Restoration Service, "We don't rebuild your calipers... we restore them." |
Eric_Shea |
Oct 11 2010, 07:58 PM
Early 914 Fronts $349.00 Per Pair: Click Here to Learn More Late 914 Fronts $349.00 Per Pair: Click Here to Learn More Early 914 Rears $349.00 Per Pair: Click Here to Learn More Late 914 Rears $349.00 Per Pair: Click Here to Learn More 914-6 Fronts $349.00 Per Pair: Click Here to Learn More Specializing in 914-6 and 914-6/GT Rear Calipers $349.00 Per Pair: Click Here to Learn More Why have us restore your brakes? Very simple. Because we do it right. The way the factory did it. The way it should be done for many reasons. Here's some common questions: "Why not just "paint" the calipers?" 1. Paint only protects the outside of the caliper... not very well and only temporarily. 2. Paint comes off with odd things like... brake fluid and brake cleaner. 3. Zinc is the factory finish and has superior corrosion protection. 4. Zinc re-plates the bore, which it probably needs it by now. Rebuilders that paint calipers do so because zinc is expensive. They can easily slap on a coat of paint on "in-house" and it speeds up the process. They can even call it cool things like "Ceramic" or "Polymer" etc. If you want your calipers done right they will need to be zinc coated like the day they left the ATE factory. "Why not buy the el cheapo mass-rebuilt, assembly line calipers other parts vendors are pushing on me?" 1. Those things cost those vendors $35.00 each. They're pushing them because there's big money to be made off you. 2. The caliper bodies are vibratory tumble polished. They put them in a huge bin of media and polish all of the finish off them. Then they get an oil bath. That's it! There is "no" protective finish on them at all! Give it a few years and your bargin calipers will literally be covered with rust. We've seen hundreds of them. The ones that come from the big-box rebuilders are almost unusable in a few short years. 3. The same process applies to your "vital" fasteners. We've seen some fasteners about to rust right through (see picture below) 4. And finally, mass production can lead to mass-problems. We've actually seen pistons in backward. Your piston step needs to be set at a precise 20 degree angle to help eliminate pad squeal. We've seen the wrong calipers delivered (there's many VW deriviatives of some of these calipers). We've seen handbrake arms with the wrong springs set to them... meaning; your handbrake is on all the time! The real benifit of zinc is the sacrificial coating properties. Zinc, by nature, will attract oxidents and literally save the metal it is protecting. Even if it is scratched off the zinc will continue to protect the steel it encapsulates. We've restored 46 year old calipers and have them come out looking brand new. All thanks to the protective properties of the zinc coating applied those many years back. Zinc also helps protect your piston bore. While the bore is not a sealing surface, it can get wear from the piston. Wear, lack of fluid changes and rusty caliper shellac will cause a caliper to stick. This usually happens just above the seal where moisture can get in. Other rebuilders use a hone to clean out your caliper bore. We recommend against that as it leaves a fresh steel on steel surface (bore and piston). The zinc bath leaves a perfect factory finish on the inside of your caliper bore. All in all, the process will clean and replate the entire caliper and make everything good for another 30-40 years. Now you know what we mean when we say "We don't rebuild your calipers... we restore them." |
914werke |
Mar 28 2012, 10:34 AM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Hey Eric aside from the single/dual bleeder difference is there anything particularly beneficial or advantageous with using the early vs late 914 rear caliper? IE aside from "correctness" for the MY application couldn't you swap early for late R. calipers w/o issue?
Eric_Shea |
Mar 29 2012, 06:24 AM
Hey Eric aside from the single/dual bleeder difference is there anything particularly beneficial or advantageous with using the early vs late 914 rear caliper? IE aside from "correctness" for the MY application couldn't you swap early for late R. calipers w/o issue? Rear calipers are interchangeable. Early have 7mm adjusters and late have 10mm adjusters. I don't see any advantages of one over the other so... Other than that and what you noted, they are totally interchangeable. |
horizontally-opposed |
Mar 29 2012, 08:19 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Lo-Fi Version | Time is now: 17th May 2024 - 12:24 AM |
