HID Lights, Where to find them? |
JBart |
Oct 13 2010, 07:07 PM
UNDER CONSTRUTION Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 |
I'm looking for a little better lighting. Does anybody know
if there are HID lights made for the 914's out there that would just plug & play for the orig. Headlamps? Thanks, Jbart |
Mike Bellis |
Oct 13 2010, 07:42 PM
H4 HID kits are available however, if you install them in a typical 7 inch housing you will blind on comming traffic. Ebay has a parabolic hybrid lens that will fit and has a horizon line. The horizon line is lit below and dark above that line. HID kits are available for just about any lamp type for around $40 pair. Here is an example of the lamp.
http://cgi.ebay.com/ebaymotors/7-INCH-DIAM...=item5d2b87885c |
Mike Bellis |
Oct 13 2010, 07:43 PM
duplicate post
Als914 |
Oct 13 2010, 07:55 PM
Lighting my way Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
I'm looking for a little better lighting. Does anybody know if there are HID lights made for the 914's out there that would just plug & play for the orig. Headlamps? Thanks, Jbart Try this source. http://www.hidonlinestore.com/category-s/5.htm The original head lamps were sealed beams. Switch to the H4 Halogen lamp housing then you can adapt to the H4 LED conversion. Good Luck. BTW are you going on the Temcula dawn patrol drive? http://www.914world.com/bbs2/index.php?act...mp;event_id=468 |
RickS |
Oct 13 2010, 10:43 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
H4 HID kits are available however, if you install them in a typical 7 inch housing you will blind on comming traffic. Ebay has a parabolic hybrid lens that will fit and has a horizon line. The horizon line is lit below and dark above that line. HID kits are available for just about any lamp type for around $40 pair. Here is an example of the lamp. http://cgi.ebay.com/ebaymotors/7-INCH-DIAM...=item5d2b87885c Is this what you are referring to as parabolic hybrid? 7 INCH DIAMOND CUT ROUND PROJECTOR HEADLIGHTS+H4 BULBS and then one uses a H4 compatible HID kit, correct? |
VaccaRabite |
Oct 14 2010, 07:17 AM
En Garde! Group: Admin Posts: 13,450 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I got mine from Pelican, using the 55 watt bulbs. At the time they sold the same kit with 100 watt bulbs. I thik you need to add a relay to the system to use the 100 watt bulbs though.
Zach |
underthetire |
Oct 14 2010, 09:43 AM
H4 HID kits are available however, if you install them in a typical 7 inch housing you will blind on comming traffic. Ebay has a parabolic hybrid lens that will fit and has a horizon line. The horizon line is lit below and dark above that line. HID kits are available for just about any lamp type for around $40 pair. Here is an example of the lamp. http://cgi.ebay.com/ebaymotors/7-INCH-DIAM...=item5d2b87885c I bought a set off Ebay, look just like those, they suck donkey balls. GIANT dark spot right in the middle, I should have just ordered the Sylvania silver stars sealed halogen. |
Mikey914 |
Oct 14 2010, 10:05 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I bought a few sets with the idea of putting together a group buy, but found they are a real pain in the butt to install, and because our headlights move over time you get blinking, and the unit will kick off. I'l stick to sylvania or other good quality bulb, it'll be allot less hassle in the end.
Just my .02 |
monkeyboy |
Oct 14 2010, 11:54 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
jsayre914 |
Oct 14 2010, 11:59 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I got my Hid from a company online. I think it was 944online or 944parts online. It was a plg and play using stock wiring. Low beam only, the highbeams do not work anymore, but the low beams shine 50 millon miles, they are unbelieveable.
I love them. Have never had a blinking out problem. check my blog for pics. |
AndyB |
Oct 14 2010, 03:49 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
They must be expensive because there is no price listed |
Mikey914 |
Oct 14 2010, 03:53 PM
Just a quick heads up I found on my research for these. You probably do wan tthe HID High/Low, it's usually a few bucks more, I did get a few sets for $85, if you want one, I'll see if I can find one. I had donated a set to the build in OK, it didn't get installed, but maybe whoevrer wound up with it could chime in.
-Mark |
JBart |
Oct 15 2010, 08:54 AM
PThompson509 |
Oct 15 2010, 10:45 AM
Member Group: Members Posts: 132 Joined: 9-August 05 From: Santa Cruz, CA Member No.: 4,564 Region Association: Northern California |
LED headlights are available from Napa:
http://www.napaonline.com/Search/Detail.as...250C_0239872601 No idea if these really work or not, but they are $308. Ouch. |
VaccaRabite |
Oct 15 2010, 11:28 AM
LED lights are problematic.
They should last longer then the car, true. And can be very bright. But they run cool. Which means they do not have the power to melt off snow and ice in crap weather, which further reduces visibility. And they are insane expensive. Zach |
monkeyboy |
Oct 15 2010, 03:54 PM
I have been running LED's in offroad vehicles for a couple of years now with no failures. If build correctly, they are pretty sturdy.
Zach, I live in Southern California. Adverse weather is when I have to wear a sweater with my shorts. (IMG:style_emoticons/default/smile.gif) I know it won't work for everyone, but it could be great here. |
JmuRiz |
Oct 15 2010, 07:14 PM
914 Guru Group: Members Posts: 5,432 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Also the LEDs only draw 5 amps for the high beams, could be awesome for our old fair-weather cars! Once the prices come down I may think about it, even though I already have H4s.
Lo-Fi Version | Time is now: 28th May 2024 - 04:41 PM |
