JBart
Oct 13 2010, 07:07 PM
I'm looking for a little better lighting. Does anybody know
if there are HID lights made for the 914's out there that
would just plug & play for the orig. Headlamps?
Thanks,
Jbart
Mike Bellis
Oct 13 2010, 07:42 PM
H4 HID kits are available however, if you install them in a typical 7 inch housing you will blind on comming traffic. Ebay has a parabolic hybrid lens that will fit and has a horizon line. The horizon line is lit below and dark above that line. HID kits are available for just about any lamp type for around $40 pair. Here is an example of the lamp.
http://cgi.ebay.com/ebaymotors/7-INCH-DIAM...=item5d2b87885c
Mike Bellis
Oct 13 2010, 07:43 PM
duplicate post
Als914
Oct 13 2010, 07:55 PM
QUOTE(JBart @ Oct 13 2010, 06:07 PM)
Thanks,
Jbart
Try this source.
http://www.hidonlinestore.com/category-s/5.htmThe original head lamps were sealed beams. Switch to the H4 Halogen lamp housing then you can adapt to the H4 LED conversion.
Good Luck.
BTW are you going on the Temcula dawn patrol drive?
http://www.914world.com/bbs2/index.php?act...mp;event_id=468
RickS
Oct 13 2010, 10:43 PM
QUOTE(kg6dxn @ Oct 13 2010, 06:42 PM)
http://cgi.ebay.com/ebaymotors/7-INCH-DIAM...=item5d2b87885cIs this what you are referring to as parabolic hybrid? 7 INCH DIAMOND CUT ROUND PROJECTOR HEADLIGHTS+H4 BULBS
and then one uses a H4 compatible HID kit, correct?
VaccaRabite
Oct 14 2010, 07:17 AM
I got mine from Pelican, using the 55 watt bulbs. At the time they sold the same kit with 100 watt bulbs. I thik you need to add a relay to the system to use the 100 watt bulbs though.
Zach
underthetire
Oct 14 2010, 09:43 AM
http://cgi.ebay.com/ebaymotors/7-INCH-DIAM...=item5d2b87885cI bought a set off Ebay, look just like those, they suck donkey balls. GIANT dark spot right in the middle, I should have just ordered the Sylvania silver stars sealed halogen.
Mikey914
Oct 14 2010, 10:05 AM
I bought a few sets with the idea of putting together a group buy, but found they are a real pain in the butt to install, and because our headlights move over time you get blinking, and the unit will kick off. I'l stick to sylvania or other good quality bulb, it'll be allot less hassle in the end.
Just my .02
monkeyboy
Oct 14 2010, 11:54 AM
jsayre914
Oct 14 2010, 11:59 AM
I got my Hid from a company online. I think it was 944online or 944parts online. It was a plg and play using stock wiring. Low beam only, the highbeams do not work anymore, but the low beams shine 50 millon miles, they are unbelieveable.
I love them. Have never had a blinking out problem.
check my blog for pics.
AndyB
Oct 14 2010, 03:49 PM
QUOTE(monkeyboy @ Oct 14 2010, 09:54 AM)
They must be expensive because there is no price listed
Mikey914
Oct 14 2010, 03:53 PM
Just a quick heads up I found on my research for these. You probably do wan tthe HID High/Low, it's usually a few bucks more, I did get a few sets for $85, if you want one, I'll see if I can find one. I had donated a set to the build in OK, it didn't get installed, but maybe whoevrer wound up with it could chime in.
-Mark
JBart
Oct 15 2010, 08:54 AM
QUOTE(Als914 @ Oct 13 2010, 06:55 PM)
Thanks,
Jbart
Try this source.
Good Luck.
PThompson509
Oct 15 2010, 10:45 AM
LED headlights are available from Napa:
http://www.napaonline.com/Search/Detail.as...250C_0239872601No idea if these really work or not, but they are $308. Ouch.
VaccaRabite
Oct 15 2010, 11:28 AM
LED lights are problematic.
They should last longer then the car, true. And can be very bright.
But they run cool. Which means they do not have the power to melt off snow and ice in crap weather, which further reduces visibility.
And they are insane expensive.
Zach
monkeyboy
Oct 15 2010, 03:54 PM
I have been running LED's in offroad vehicles for a couple of years now with no failures. If build correctly, they are pretty sturdy.
Zach, I live in Southern California. Adverse weather is when I have to wear a sweater with my shorts.
I know it won't work for everyone, but it could be great here.
JmuRiz
Oct 15 2010, 07:14 PM
Also the LEDs only draw 5 amps for the high beams, could be awesome for our old fair-weather cars! Once the prices come down I may think about it, even though I already have H4s.
