Correct lug nuts (bolts) and center caps, for my 1974 steelies |
RFoulds |
Oct 21 2010, 01:52 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
Just realized, I only have the black lug bolts, and the black plastic center caps, currently on the car with the Riv wheels. When I use the steelies for Concourrs, what will be the correct lug bolts and caps to use?
Any pics of caps will be much appreciated. Attached image(s) |
JeffBowlsby |
Oct 21 2010, 08:26 PM
914 Wiring Harnesses Group: Members Posts: 8,486 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
These are what you want. Sorry I have no better photo. Last I knew, the center caps were still available new, but that may be out of date info.
Tom_T |
Oct 21 2010, 09:29 PM
I think the lugs are 25 mm (vs 38 mm on alloys) & black as Jeff's pic shows.
Also, look at the nailed Wheels & Tires thread on O&H Forum, as IIRC someone posted a proper stock 73-76 Steelie on there & on a 914. |
JeffBowlsby |
Oct 21 2010, 10:57 PM
Voila...
sixerdon |
Oct 22 2010, 07:06 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Keep in mind that the steel lug bolts have black plastic caps that slide on them
as shown in the above pic. So that's 3 sets of each item you need. Don |
RFoulds |
Oct 22 2010, 01:26 PM
Thanks everyone. Jeff, that pic is exactly what I needed. I have sourced the bolt caps and center caps through a board sponsor, but I am unsure about the bolt length.
Anyone know for sure?? |
Pat Garvey |
Oct 28 2010, 06:28 PM
Thanks everyone. Jeff, that pic is exactly what I needed. I have sourced the bolt caps and center caps through a board sponsor, but I am unsure about the bolt length. Anyone know for sure?? 28mm, according to the factory tech specs manual, page 52. Tom T is correct. P |
914werke |
Nov 5 2010, 12:05 AM
"I got blisters on me fingers" Group: Members Posts: 10,035 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Slap some chrome trim rings on those steelies, looks 100 % better
mrgreenjeans |
Feb 24 2011, 06:21 PM
mrgreenjeans Group: Members Posts: 213 Joined: 9-February 07 From: N.Dak. Member No.: 7,520 Region Association: Northstar Region |
Slap some chrome trim rings on those steelies, looks 100 % better Sorry, couldn't disagree more in regards to the trim rings. Just take a walk down a concours lawn with 914's all arranged without their trim rings, and its a thing of beauty...... Same goes for a 69 Boss with its Magnum 500's or a GTO or Chevelle with their steel mag wheels. Nothing is prettier than a simple painted wheel with one center hubcap and a painted background uninterrupted by chrome. ESPECIALLY on a Serious high performance car, where the trim rings just fell off on the road course or the drag strip only to be run over by the next car. Like the Charger in BULLIT shedding its wheelcovers on the SF streets.......... |
monkeyboy |
Feb 25 2011, 01:03 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Slap some chrome trim rings on those steelies, looks 100 % better Sorry, couldn't disagree more in regards to the trim rings. Just take a walk down a concours lawn with 914's all arranged without their trim rings, and its a thing of beauty...... Same goes for a 69 Boss with its Magnum 500's or a GTO or Chevelle with their steel mag wheels. Nothing is prettier than a simple painted wheel with one center hubcap and a painted background uninterrupted by chrome. ESPECIALLY on a Serious high performance car, where the trim rings just fell off on the road course or the drag strip only to be run over by the next car. Like the Charger in BULLIT shedding its wheelcovers on the SF streets.......... As I remember about 25 wheelcovers fell off during the chase... (IMG:style_emoticons/default/smile.gif) |
scotty b |
Feb 27 2011, 02:40 PM
What waa the correct finish on the lugs? I have a drawer full of them ( Beetle and 914 ) that need a good cleaning and re-coating/plating.
Same on the longer alloy lugs. they appear to have been painted silver (IMG:style_emoticons/default/confused24.gif) |
davep |
Feb 27 2011, 06:18 PM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The stock bolts were just phospated. The beetle bolts are shorter than the 914 bolts. but can be used on the front. The 914 bolts are longer to have the same thread engagement depth when used on the rear (going through the brake rotor).
The alloy wheel bolts were copper plated, then cadmium plated. |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:54 AM |
