| biosurfer1 |
Oct 21 2010, 08:27 PM
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I love my 914 but two things that really bugged and embarrassed me about it was I had no e-brake so I would drive around until I found a flat parking spot and hope leaving the car in gear held it and when I put my Renn-shift on, a couple things got moved a bit in the tunnel and I had a very annoying grinding/squeeking sound when I shifted into 1st. I knew it wasn't doing any damage but it was always there.
I couldn't really tell what was causing the noises in the shifter and I don't usually mess with brakes, I leave those to professionals. So what's the easiest way to fix both of these items? Step 1: Take 914 to McMark's shop in Sonoma. Step 2: Go on vacation to the Bahamas Step 3: Come back, give Mark minimal $$$'s and everything will be fixed! Seriously though, Mark has gone above and beyond for me more than once with knowledge and, on more than one occasion, emergency storage. I'm lucky to have him so close. I'm a big advocate on learning how to work on your own car, but when things elevate to the point of needing a professional, I highly recommend Original Customs. Thanks again Mark! (IMG:style_emoticons/default/first.gif) p.s. Olav can (IMG:style_emoticons/default/KMA.gif) |
| SirAndy |
Oct 21 2010, 08:53 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I had no e-brake 10.5:1 has worked well for me in the last couple of years ... (IMG:style_emoticons/default/biggrin.gif) |
| jcd914 |
Oct 22 2010, 12:29 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
A couple of blocks of wood or bricks help (IMG:style_emoticons/default/smile.gif) You can't go wrong sending it to McMark but assuming you still have stock rear brake calipers you can probably fix the parking brake your self. The system is fairly simple, hand lever pulls on the cables, cables pull on the caliper levers. Disconnect the cables at the calipers Make sure the caliper levers operate back and forth without sticking Adjust the venting clearance on all 4 rear pads. Adjust the length of both cables so they connect to the caliper levers with no pre load or extra slack On the shifter I would pull the rear cover off the center tunnel and operate the shift lever while watching the shift rod and see if you can find what it is rubbing against. Move what ever is rubbing out of the way or maybe you need to shift the Renn shift tower a little to one side or the other. Jim |
| r_towle |
Oct 22 2010, 08:00 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
bring it to mark.
the squeak is the shifter rod rubbing againsts the inner tunnel wall or rubbing on the clutch tube. You can get rid of it by adjusting the side to side throw of the shifter, or twisting the rod one single click (it is toothed) I chased that one after I listened to it long enough. For the e-brake...just have Mark fix it all. You will need your rear brakes adjusted, and most likely new or rebuild cables..alot of grease, and some time...most of that will be time, not parts. I also carry around a little fold up chock block I got in some emergency kit long ago...I open the door, put it on the ground, and then roll up to it... This way I dont have to get out of the car...but you need to plan when to do it so you have enough room. Also, you need to remember to remove it...that always makes me feel like an ass when I try to move my car and it wont move...then I remember why it wont move. Rich |
| Drums66 |
Oct 23 2010, 11:26 AM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....Please do until you install 1 (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 4th March 2026 - 05:12 PM |
