| jeffdon |
Oct 23 2010, 01:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Got a wierd one. My turn signals all work fine with the headlights off. With them on, the rights work, but the lefts (front and rear) do not. What could this be? For what its worth, but I dont think its got any effect, I deleted the hockey puck side markers.
| Drums66 |
Oct 23 2010, 02:43 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
...Check the bulb socket's 1st (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) |
| Mike Bellis |
Oct 23 2010, 02:47 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
The front left turn signal housing is wired wrong. you system is pulling its ground through the head light circuit. Possibly the front left signal ground is broken
| 76-914 |
Oct 23 2010, 03:02 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,995 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
The front left turn signal housing is wired wrong. you system is pulling its ground through the head light circuit. Possibly the front left signal ground is broken You gotta be a Double E, Mike. Sell that one to George and his next book can be 701 Tech Tips (IMG:style_emoticons/default/lol-2.gif) |
| Spoke |
Oct 24 2010, 10:47 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,438 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
The front left turn signal housing is wired wrong. you system is pulling its ground through the head light circuit. Possibly the front left signal ground is broken (IMG:style_emoticons/default/agree.gif) Remove the turn signal lense and make sure just the bright filament is on when the turn signal is on. This will confirm the issue. Also with the parking light on, just the dim filament should be lit. |
| kenshapiro2002 |
Oct 25 2010, 05:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Mine was the relay
Lo-Fi Version | Time is now: 26th November 2026 - 04:53 AM |
